POV DIY video series - Your suggestions needed!
#101
Originally Posted by Soviet' timestamp='1473657275' post='24060022
[quote name='steven88' timestamp='1473656501' post='24060020']
Hi Jason. Great video on the rear coilover install. But quick question. You didn't mention preloading the bushings before tightening the A-Arm bolt. Do you feel that it's needed?
Fortunately, I'll be doing another set of coilovers this week that I can film and eventually revise. Thanks for pointing that out Steven.
To be honest you should clock every single part of the suspension that uses a rubber bushing, including the top hats.
[/quote]
Thanks for the info as always, before I post the video I'll send it your way.
#102
Been absolutely busy the last 3 weekends and haven't had an opportunity to do much editing. Will try to crank out a few videos this week.
HarryD (03-20-2017)
HarryD (03-20-2017)
The following 2 users liked this post by Soviet:
HarryD (03-20-2017),
Slowcrash_101 (04-26-2017)
#105
Wow! I've done a really poor job updating this thread. I've ramped up production lately and tackled some of the requests in this thread.
I've started to do some more discussion type videos on the common S2000 problems like this that aren't strictly DIY but are visual aids
Going through the backlog of stuff I've always wanted to do..
This was a highly requested video that I should probably share more often in clutch pedal freeplay threads
Lastly, delving into some light mods on the CR
phew!
phew!
The following 4 users liked this post by Soviet:
#106
You're doing God's work.
#107
Your "clutch pedal freeplay" video is outstanding.
Take note of where the narrator says, "turn the rod until resistance is felt".
Once you hit the resistance, the linkage play is absolute zero. In reality, it is 1% to 3% movement of the master piston.
This setting is absolute optimal. As you will still have 96% reserve zone before pressure is built against the fluid itself.
Hard to understand and even harder to convey with words. Just follow that vid to the T and enjoy a perfect shifting car.
#109
Great work, Thanks!
Really enjoy your vids, helps make working on this amazing car so much better.....!!!!
