Propeller Shaft play...How much is TOO MUCH?
Glad I stumbled on to this thread. Having similar symptoms with about 230k miles on my original driveshaft. Didnt even know they were serviceable
To note though, the back and forth play isnt in the driveshaft but in the trans/diff backlash in the gears, which is normal to some degree. How much is hard to say. But the vid looks like pretty normal backlash. That's not to say there may not be some vibration coming from the driveshaft that a repack would wouldn't solve. Its what i'm hoping for.
In a u-joint system with a splined slip-joint, the spline can be put together out-of-phase. The result is the two shafts actually try to turn at two different speeds (non-constant velocity) at any given instant, even though they make the same amount of revolutions. The fight between the two distinct velocities causes pressure differences, creating vibration and accelerated wear.
This is not possible with the S2000. The markings are the same as the paint on the transmission drain and fill, or the axle nuts. They provide a story of preservation, or evidence of alteration/tamper/movement. They are not for phasing or balance.
Noble (05-27-2019)
jor-don
06-16-2014 07:43 AM
SIMAS
08-17-2013 09:15 PM
