ran low on oil and killed the engine, what are my options
Car is a 2002 ap1, stock, with 140k on the clock, daily driver. Ran low on oil and is now making an awfully loud ticking, pretty sure the engine is toast. I'm going to take the oilpan off next weekend, and also planning to check under the valve cover. From what I've read on here, it's most likely one of the bearings went.
I think a used engine is probably my cheapest / easiest option. Do I stay away from JDM engines? Or will it just "plug and play" with my US cars wiring and ECU? Do I have to find a 2002 engine? Or will any AP1 work? What about an AP2 engine? Anyone recommend a good way to find a used s2000 motor in the LA area?
Just wanted to get some input on what my options are. Thanks for the help.
maifren22 (10-02-2017)
Good luck!
Its possible you may be able to save the motor. The process would be:
Remove pan
Remove rod caps, inspect bearings, inspect crank
If crank is not too bad, you can carefully hand polish crank
Then replace bearings with same size bearings from factory (this hand built engine used several possible bearing sizes to compensate for manufacturing tolerances)
Check everything with plastigauge
Assemble with assembly lube
Perform a break in cycle for your driving style for the first 1k or so miles, using dino oil (not synthetic) do oil change
This is not a diy to learn on your own. You want someone that has experience with this to be involved.
But if your crank isn't toast, you could potentially fix this for not a lot of cash.
Remove pan
If you meant LA as in Los Angeles and not Louisiana, I have heard HMotorsonline is a reliable source for engines. I believe they may have an F20C engine available that will fit your car but it's gonna cost you. They are in the Los Angeles area.
Thanks for the input guys, I'll report back after the weekend.
If the crank bearings went, how do I rule out that the head is still good? Wouldn't metal bits have found their way up there and damaged things?
Thanks for the tip, I had not heard of them, but they apparently a few blocks from my house.
If it comes down to me needing a new engine, is there anything to worry about with running the JDM motor on the US ECU that's already in the car?
If I go the F22C route, I should avoid running it with my 02 ECU right? It'll run too lean? If I go with the 04-05 motor and ECU, I'll need to have the key programmed for the new ECU?
JDM motors have slightly higher compression, but the computer can compensate for 91 octane piss water. Use JDM engines with confidence.
The in-the-car rod bearing replacement approach suggested is, essentially, a prayer that the damage is limited to a worn rod bearing.
If the crank is still good and the rod bearings are not too badly worn then it is hard to imagine where metal bits would come from to damage the head.
If it really bothers you, you can pull the head, inspect the cylinder bores, pop the pistons out, inspect the pistons and rings, disassemble the head, clean everything, look for damage, replace worn parts and then reassemble it. But that's a lot of work and money if the main bearings are shot which you won't discover during an in-the-car rebuild.
You can run a compression test after you replace the rod bearings and see if any of the cylinders are down on compression, suggesting cylinder wear or valve damage.
If the quick bearing change doesn't solve the problems, you now have to choose between a real rebuild and a junk yard engine.
