Rear Axle Nut TSB - DIY
#101
Just did this tonight, it wasn't nearly as bad as I thought it would be. I think it took me a total of 15 minutes to do both wheels. Using a cheater bar helps a lot, I picked one up from Home Depot that's about 4 feet for pretty cheap. I don't have any 3/4 drive tools in my collection so I went to Harbor Freight and they wound up having a 3/4 drive tool set on sale that comes with a breaker bar, ratchet, a couple extensions, and a lot of sockets (including a 36mm) which turned out to be perfect for this job. I would argue that you could rename this tool set the "s2000 Rear Axle Nut TSB Tool Set".
I have pretty good upper body strength but I was still a little worried I wouldn't be able to do this job by myself. Using the cheater bar and 3/4 drive tools made this job super easy, I was pretty surprised and happy with the results. Getting the nut to move an extra 60 degrees was no problem at all.
Thanks for the write-up and info guys!!
#103
Will this corded electric impact wrench work to loosen and tighten the axle nut? It says its good for Torque Ft./Lbs:350 ft. lbs. Im going to be doing this soon and need to decide between a breaker bar or an impact wrench
http://www.sears.com/craftsman-8-amp...2&blockType=G2
#106
Ive been daily driving my car like this for months. It started handling funny a week ago. I decided it was time to fix the "bearing" did some research. When I looked for the axle nut, it was missing and the thread was sheered off. Broken. Gone! I parked it at my parents and borrowed my dads truck. My question is: how dangerous was this? There are only two shops that my S has been in: The Honda dealership and Discount Tier. The Honda dealership tightened it over half a year ago so I doubt it was them. Since then, I got new wheels with bald tiers. When I swapped the wheels, the nut was still on and good. Discount Tiers told me that I had a bad wheel bearing, but other then that my car looked great. I put it off to fix later. My theory is, one of the technicians decided to "fix" the problem by tightening the NUT, snapped it off, didnt tell anyone and here I am.
Question 1: What will I need to fix this and how much will it cost without labor (part numbers would be really helpful)
Question 2: Could this have been overtightened and then snapped off while I was driving? Is this possible, or only during tightening with a crazy shop air powered impact wrench?
Question 3: Do I have a case against Discount Tiers? Willful Negligence? Is it worth perusing it 2 months after the fact?
#107
Just did this today on both sides. Driver side started clicking last week and I'm glad I ran into this thread. Thanks for the write-up. Very easy job, took me a little longer because I had to drive out to Lowe's to get a cheater bar. Sound is gone, hopefully it won't come back!
#108
I have had a slight wurring sound that appears to be coming from thecdrivers side rear wheel between 60 mph and up. 2005 with 70k miles. Anyone think my bearing is going? I did get a few slight clunks from the rear lately too while turning hard.
