Rear bumper bolts
I need to pick up longer bolts for the rear bumper to mount my hitch brackets (home made). Anyone know the size (8mm?), thread pitch (1.25mm?), and length (20mm?) of the five bolts holding on the rear bumper?
I know I should've measured them when I was test-fitting the hitch, but I didn't; and I'd like to avoid taking off the bumper cover until I've got the hardware to install the hitch brackets. |
Which bolts are you removing? There should be 2 screws at the corners, and a row of clips at the bottom and top of the bumper cover?
The beam behind the cover should attach with 8x1.25 bolts, the length should be around 25mm |
