rear end vibration under acceleration with brand new driveshaft shop axles.
Old Dec 28, 2013 | 11:19 PM
decepticondc5's Avatar
Default rear end vibration under acceleration with brand new driveshaft shop axles.
I had no vibrations before taking my car down to change hubs and bearings in the rear but i went ahead and replaced the stock axles with some level 0 axles from drive shaft shop just to future proof the car a little bit. I am now getting a vibration only under acceleration from about 40-60 mph which seems to trail off after that. Everything that i have been looking up points to CV buckets but the axles are brand new. Im pretty sure I installed the bearings and hubs correctly; I followed the DIY on robrobinette.com to a tee with the updates from billman about how to support the bearing races and everything.
-The wheels seem to spin freely enough when up in the air so i do not think it is a hanging brake caliper.
-Tire pressures are good and the alignment is fine.
-Axles are BRAND NEW name brand units.
-Fairly certain I installed the bearings and hubs properly.
Old Dec 29, 2013 | 03:48 AM
S2KPUDDYDAD's Avatar
Are the DSS axles you bought a Honda rebuilt axle or a solid shaft reman?
Old Dec 29, 2013 | 03:53 AM
silverstone05's Avatar
Those axles are garbage. Send them back get rid of them etc! Put your old ones in. Or buy new Honda ones!
Old Dec 29, 2013 | 05:05 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
We just had a thread on this. Take a pic of the axle shaft.
If its solid shaft, it's going to vibrate.
Old Dec 29, 2013 | 07:06 AM
They are definitely solid shafts.
I am going to go swap them back to oem honda parts now and will report back later with the results. Thank you everyone.
Old Dec 29, 2013 | 07:52 AM
Those do not work for our car as you well know now, this has been an issue for a long time, I hope you can get a refund
I hope the vendor will take note to this issue and care about the quality and performance of the parts they sell.
Old Dec 29, 2013 | 07:53 AM
It's dss they sell nothing but garbage IMHO and don not have good warranty or refunds. I would never buy from them. Again MY OPINION.
Old Dec 29, 2013 | 02:40 PM
Swapped back to oem axles....
Old Dec 29, 2013 | 02:57 PM
noodels's Avatar
well done
Old Dec 29, 2013 | 07:43 PM
did you get a refund?
