S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Under The Hood (https://www.s2ki.com/forums/s2000-under-hood-22/)
-   -   rear end vibration under acceleration with brand new driveshaft shop axles. (https://www.s2ki.com/forums/s2000-under-hood-22/rear-end-vibration-under-acceleration-brand-new-driveshaft-shop-axles-1065013/)
decepticondc5 Dec 28, 2013 11:19 PM
I had no vibrations before taking my car down to change hubs and bearings in the rear but i went ahead and replaced the stock axles with some level 0 axles from drive shaft shop just to future proof the car a little bit. I am now getting a vibration only under acceleration from about 40-60 mph which seems to trail off after that. Everything that i have been looking up points to CV buckets but the axles are brand new. Im pretty sure I installed the bearings and hubs correctly; I followed the DIY on robrobinette.com to a tee with the updates from billman about how to support the bearing races and everything.
-The wheels seem to spin freely enough when up in the air so i do not think it is a hanging brake caliper.
-Tire pressures are good and the alignment is fine.
-Axles are BRAND NEW name brand units.
-Fairly certain I installed the bearings and hubs properly.
S2KPUDDYDAD Dec 29, 2013 03:48 AM
Are the DSS axles you bought a Honda rebuilt axle or a solid shaft reman?
silverstone05 Dec 29, 2013 03:53 AM
Those axles are garbage. Send them back get rid of them etc! Put your old ones in. Or buy new Honda ones!
Billman250 Dec 29, 2013 05:05 AM
We just had a thread on this. Take a pic of the axle shaft.
If its solid shaft, it's going to vibrate.
decepticondc5 Dec 29, 2013 07:06 AM
They are definitely solid shafts. :feint:
I am going to go swap them back to oem honda parts now and will report back later with the results. Thank you everyone.
S2KPUDDYDAD Dec 29, 2013 07:52 AM
Those do not work for our car as you well know now, this has been an issue for a long time, I hope you can get a refund
I hope the vendor will take note to this issue and care about the quality and performance of the parts they sell.
silverstone05 Dec 29, 2013 07:53 AM
It's dss they sell nothing but garbage IMHO and don not have good warranty or refunds. I would never buy from them. Again MY OPINION.
decepticondc5 Dec 29, 2013 02:40 PM
Swapped back to oem axles....
http://static3.wikia.nocookie.net/__...e_original.jpg
noodels Dec 29, 2013 02:57 PM
:thumbup: well done :tipwink:
silverstone05 Dec 29, 2013 07:43 PM
did you get a refund?
© 2026 MH Sub I, LLC dba Internet Brands
