View Poll Results: Is the knuckle okay to use?
Yes
60.00%
No
40.00%
Voters: 5. You may not vote on this poll
Rear Knuckle has a slight indent with Pics
Old 06-08-2019, 02:23 PM
ronaldluang's Avatar
Default Rear Knuckle has a slight indent with Pics
I pressed the rear bearing in using a cup as a backing support to center the rear knuckle. What I didn't realize at the time was the cup was off center and so when I pressed in the wheel bearing the cup ate into the rear knuckle. It left some indentation marks where the axle rest on the outer side as shown in the pics and the inner side of it (not shown in pics but you can see kind of see it since it's directly on the opposite of the outer side). Since it's not uniform and smooth anymore do you think it will be okay? I don't want any unnecessary vibrations or suspension failure.
Old 06-08-2019, 02:37 PM
noodels's Avatar
Looks cracked
Old 06-08-2019, 05:24 PM
fatjoe10's Avatar
This happened to me before. What will happen is that the axle will rub against that and make a lot of noise unless u grind down the deformed portion. In my case, the knuckle was fine afterwards.
Old 06-10-2019, 04:41 PM
G2G
G2G's Avatar
Yeah, that's just a snap ring, grind or sand/buff down the raised material until it is flush with the rest of the undamaged surrounding material and you'll be fine.
kendash
03-09-2006 04:44 PM
Quick Reply: Rear Knuckle has a slight indent with Pics
