Removed Valve cover and lots of rust found.
#21
#22
Man! That cam surface looks bad. How's the floor pan? Suspension parts?
#23
I was thinking of doing a bg additive that breaks down build up(sludge, carbon and contaminates) to see if that cleans up anything and reduces wear. We sell that at the shop btw, I've personally never used our products, unless its for like the brake fluid, trans fluid, cooling additive and drive train etc. lol
#24
Honestly everything in the car looks great. No body damage, the interior is clean except for the d/s seat material from the cushion releasing debris. The top is in great shape, I don't see rust anywhere on the body of the car except for a few bolts but nothing major. the under carriage is in excellent shape, all the suspension and bushings are intact and in good condition. The exhaust system doesn't have rust considering the age and how Honda's age with rust on the exhaust is quite surprising. The car is in good shape, but still, there is the chance this is a flood car.
#25
my initial thought was that it was a combination of varnish, sludge and perhaps some rust. Low quality oil not changed for long periods of time, some build-up of condensation etc. Make sure the pcv system is working properly, inspect/change the pcv valve if necessary. The build up of whatever it is won't affect performance or longevity of the parts so I wouldn't change the cams or other parts initially. I would try a clean up process first such as a BG treatment, auto-rx is also a great product that you can use yourself with a treatment regimen, you can see it at their website auto-rx.com , lots of guys at bobistheoilguy.com swear by it. Follow up by running a high quality synthetic and things will clean up over time, you can also try some short runs of high-mileage oils. My engine had some varnish on it when I got my car, I ran some Riselone concentrate in it for a bit, followed up by some short runs of high mileage oils, then constant diet of high quality synthetic and the engine came out spotless. I would try to clean it up if it was mine.
#26
Not sure that cam surface can be cleaned or fixed to a point, where it won't wear quickly, in use. Pretty deep rust. Hardened surface maybe shot.
#27
The rust is from a very prolonged period of the engine sitting dormant, likely without the oil cap.
The cams should be removed (easy) and can be spun at low speed in a lathe, and hand polished with emery cloth.
#28
Surface rust, cams are iron, happens when you let the car sit. As said above easily removed, I would go as far as to say leave it be. The roller rockers seem to be intact, and I'm guessing the engine spins freely by hand. When you drained the old oil did you see anything in the oil other just dark dank oil?
#29
Thanks for the input. With that being said, are you saying to manually clean up the build up on the valve train by hand? And then perform a oil additive from bg or auto-rx? A mechanic at the shop who I'm good friends with (20+yrs exp.) said that I should not worry about the build up, just to do frequent oil changes and keep an eye out for odd noises if it ever does occur. He says that this is not a catastrophic failure type of build up. But I'm obviously still concerned because i want to keep the car for a long time. I've been dying to drive and own a s2000 since they came out. And i finally got one, that drives just superb and looks fantastic. But at the same time I want to be cautious be cause i have been and do take it to 9k rpms from time to time while driving.
