Replaced tct timing chain tensioner and hear a supercharger whine noise
Old 11-27-2014, 12:13 PM
  #41
windhund116's Avatar
Received 1,424 Likes on 954 Posts
JOC... the mating surfaces are clean and free of "tweak marks" from previous installations? Making sure surfaces are flat with no "hickey marks" may help seal the surface evenly. Light, even sanding.
I use a fine grit sandpaper (like wet-or-dry 400 or 600 grit) on a nice flat metal plate --- to kinda surface parts (esp aluminum ones) --- before installation.
Old 11-27-2014, 06:48 PM
  #42
BigBang's Avatar
Originally Posted by merkis1024
I had a very similar problem, although my leak started before the ballade TCT was installed. Root cause was unrelated to the TCT as well.
Tried replacing the vtec solenoid gasket. still leaked.
tried re-tightening the pressure switch. still leaked.
It turned out that the pressure switch's silicon seal had worn off. unscrewed the pressure switch and put silicon then installed it back. no leak since.
Are you in socal? If so, try a visit to Ballade. If not, i'd at least give him a call.
I think I have the same problem as you. Right below my vtec solenoid I can see a very small amount of oil leaking. Runs all the way down to my oil filter. Not quite sure if I should replace the vtec solenoid or just the o-rings?
Old 11-29-2014, 07:38 PM
  #43
Banned
weekendwarrior44's Avatar
Originally Posted by jordanksartell
Ah good! Looks way bigger in the pic than I remember it being.
Wtfffff I changed the gasket with the little filter that goes against the head, the entire switch on the side of the solenoid WITH a new o ring as well and still leaking. I keep finding the oil inside the plug there on the side of the solenoid as shown in this pictureReplaced tct timing chain tensioner and hear a supercharger whine noise-xkhvcvc.jpg
Old 12-02-2014, 08:48 AM
  #44
dustin02rsx's Avatar
so did you ever solve your whining issue?
Old 12-03-2014, 12:15 PM
  #45
Banned
no, it may just be me being paranoid, it's not that loud.
Old 08-12-2017, 10:51 PM
  #46
lleon08.s2k's Avatar
So no fix for it. I have the same noise. I'm sure that whining noise is not normal. I'm already trying to result to replacing the idler gear and timing chain at this point.
Peeves
10-17-2015 08:46 AM
Forziii
03-08-2014 12:34 PM
SOL1D
02-16-2011 11:42 AM
JohnEan90
03-06-2010 11:53 PM
bigwhite
07-30-2006 05:24 PM
Quick Reply: Replaced tct timing chain tensioner and hear a supercharger whine noise
