Replacing front rubber brake lines - am I getting ripped off?
After replacing the rotors and pads on my car (MY 2000, stock), I noticed it would pull to the right under medium-to-hard braking. I got an alignment, checked the tire pressure, and did a visual check on the lines which looked normal. Problem still occurring (though not as much). I took it to Firestone and they said I had a leak in the front rubber line which was causing the air in the system and one front caliper to exert more pressure than the other.
To replace the two rubber brake lines and do a fluid flush, they quoted me $449 ($230 of which is parts). It seems a little high, particularly the parts.
Is this a reasonable price for this job? I would consider doing it myself but I'm tracking it next weekend and will not have time to finish it before then.
This is the parts diagram of brake lines for an 06.->http://www.hondaautomotiveparts.com/...%29+%28+06-%29
You can see how much each brake line set costs.
This is the brake fluid that many people use as far as I know->http://www.amazon.com/Motul-RBF600-B.../dp/B0011E2Y0I
I think you need 2 bottles for flush.(1L total)
As for the labor, that depends on the shop.
In my opinion, 450$ is a little bit more than I would pay for a job like this.
Thanks! The lines from Firestone are being quoted at more than 3x the price on the Majestic Honda website. I'm going to see if I can get a quote from a Honda dealer.
Unfortunately, neither Firestone nor the Honda dealer will use my own brake fluid (usually get ATE Type 200), so I'll probably end up doing the flush myself because I know the regular fluid will boil when I track at.
It seems like a super simple job...maybe I'll be able to squeeze it in before work one night this week.
Originally Posted by redlineracing' timestamp='1428267234' post='23567501
That's too much and it's pretty much a DIY job.I paid about $100 for my 4 SS lines.
Labor at most ( except at a stealership) should e about $100.
\rlr
Carolina
\rlr
Carolina
Originally Posted by lappj' timestamp='1428281489' post='23567658
[quote name='redlineracing' timestamp='1428267234' post='23567501']
\rlr
Carolina
\rlr
Carolina
[/quote]
The kits I saw were separate for front and rears. But agreed - doing all four makes sense. Thanks for the help guys. I think I'll do it myself.
In my opinion, hardest part of changing lines are not changing lines but the flush itself so while you are doing that it is only extra 5 minutes. There are plenty of DIYs you can find. Save that 450$ for more track days
If you have a leak in a brake line, you will loose fluid fast.
And it will show.
Fluid everywhere.
Did they replace the rear pads too?
Check if the pin on the pad facing the piston is in its slot.
New pads and rotors may take time to start working well, it all needs to wear in, and pad material needs to be embedded into the rotor.
That takes time.
A sloppy mechanic, with greasy hands, may have installed a greasy rotor.
Grease on brakes = bad.
Do not start replacing parts if you do not know what's wrong.
