Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Replacing OEM ECU - is dealer necessary?
Notices
Old 03-03-2019, 01:15 PM
Liked 0 Times in 0 Posts
Default Replacing OEM ECU - is dealer necessary?
I purchased an AP1 OEM ECU from another vehicle to install in my AP1, it came with lock cylinders, ignition cylinder and keys.
1) Do I need to incorporate any of those extra items when swapping ECUs?
2) Do I need the dealer to flash the new ECU to my car for it to work?
Backstory: My car was burgled 6-7yr ago, in their haste to steal my parts they left some vac-hoses and wire disconnected. CEL P0411, reconnected everything, reset ECU, still have same CEL. Test my SAI pump, it's fine & so is the fuse (or relay? I forget). We install a SAI bypass, but yet.. the code comes back without fail. After running out of culprits, we determine the ECU may be my problem as I drove it with the CEL until tags expired. I'd drive (sparingly) with expired tags but the past couple years have barely driven it at all and really need to get it legal again. I've owned it 11 years and really miss driving it as I please, driving it with bad tags is too risky to enjoy :[
Pic for grins :]
Crab Rangoon is offline
Old 03-04-2019, 07:21 AM
Liked 2 Times in 2 Posts
This past year I replaced my ECU with a used one from ebay. I found a local locksmith to reprogram it to work with my keys for about $100. So your options are to either swap everything out or reprogram the new ecu to work with your current key set (by either the dealer or a locksmith).
whippets2k is offline
Old 03-04-2019, 09:52 AM
flanders's Avatar
Liked 129 Times in 126 Posts
flanders is offline
Crab Rangoon
06-26-2013 06:45 AM
R1_Pilot
01-08-2010 11:53 AM
Trigun
01-07-2010 04:46 PM
killasystems
02-01-2008 05:56 AM
Envied
08-11-2007 10:52 PM
Quick Reply: Replacing OEM ECU - is dealer necessary?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
