Rev limiter at 6000!
i know that the S has an early rev limiter if the engine is cold ...... the temp is on 3 bars and i drive for over half an hour and the rev limiter sticks to 6000 and vtec doezn't kick in .... the limiter is very hard ......... any solutions??? its been like this for 2 days now!!!
check your oil level .
No joke! Send me a pM please! |
just checked my oil level ......... it is low oooops ..... will top it up and c if solves the problem
Problem will be solved .
Vtec will not engage when the oil level is to low . |
yep, you fixed it
well i changed my oil and filter ..... for the first 15 minutes the car was driving back to normal but then the rev limiter went back to 6000 instead of 9000!! ...... so the oil level wasnt the issue i guess ... any suggestions??
which filter am i supposed to check? the oil filter or the intake filter?? .... my oil filter was changed today .... or is it some other filter alltogether?
listen for any vacuum leaks and inspect all your hoses.. When i had this issue it was the oil level. Im purely guessing but have you ever changed your fuel filter yet?
