Roll bar question '04 s2000
What function does the "roll bar" actually perform/assist?
Does it (a)affect the "speed" or "rate" of the lateral transition? -or- (b)does it reduce/control the rate of body roll? I had an '03 s2000 and I would like to "quicken" the lateral transition on my '04. Will a stiffer roll bar achieve this? Example: Will the '03 and prior roll bar (stiffer) quicken my lateral transition?, and what other changes will I notice, ie, stiffer ride, reduced suspension compliance, etc. Thanks for your help. KMazman |
Are you sure you want to be asking about a rollbar? Sounds more like a sway bar question.
Originally posted by mazman What function does the "roll bar" actually perform/assist? Does it (a)affect the "speed" or "rate" of the lateral transition? -or- (b)does it reduce/control the rate of body roll? I had an '03 s2000 and I would like to "quicken" the lateral transition on my '04. Will a stiffer roll bar achieve this? Shock absorbers change the rate of roll... |
Less compliance in the suspension and the tires will make the car respond quicker.
Yes, I mean sway bar.
So, if I increase the stiffness of the sway-bar will I gain faster lateral response? Yes? I like the suspension compliance of the '04 but would like to increase(quicken) the lateral response to be more like my '03 s2000. It sounds like I can achieve this by stiffening my sway bar. Is this true? I understand that less compliance in the tire/suspension set-up will also achieve this. However I am curious as to what a stiffer sway-bar will do to my car. Thanks again. |
Originally posted by mazman Yes, I mean sway bar. So, if I increase the stiffness of the sway-bar will I gain faster lateral response? Yes? I like the suspension compliance of the '04 but would like to increase(quicken) the lateral response to be more like my '03 s2000. It sounds like I can achieve this by stiffening my sway bar. Is this true? I understand that less compliance in the tire/suspension set-up will also achieve this. However I am curious as to what a stiffer sway-bar will do to my car. Thanks again. |
This may help:
http://forums.s2ki.com/forums/showthread.p...threadid=172489 |
