The RR Journals: Octane and fuel economy
Over in the TL forums, there was the usual "premium vs regular" thread, and it got to the point of absolute stupidity - such as "I used regular and mt MPG went down by 25%". That kind of thing.
Then, some Einstein "mathematically proved" that regular was unjustified, based on a 1-2 MPG cariation.
I go fed up with the whole thing, did some research, and found something you all might find interesting.
Short version? The max difference in fuel economy between regular and premium is 3%.
3%!!!!
http://tl.acurazine.com/forums/showthread....d=1#post1027351
3%!!!!
91+ octane costs more and it is called "Premium" so it must be better. Kind of like JDM coilovers or slotted rotors or "performance street pads" or aftermarket exhaust systems or....
Originally Posted by gernby,Nov 20 2004, 08:28 PM
I am surprised that there would be any difference at all in fuel economy between octane ratings as long as it is high enough to prevent pre-detonation.
I know I could much more drastically affect my gas milage by keeping my RPMs lower, but where's the fun in that?
The way I see it, if the ECU doesn't detect any pre-detonation, then it will run "optimal" timing. I doubt the ECU would notice any difference between 93 and 100 octane fuel on a stock car.
Per RR's link in the TL forum:
http://www.chevron.com/prodserv/fuels/bull...ormance/pg4.asp
It is an interesting read. I always blamed ethanol for my poor gas mileage. Maybe it is not the problem?
Interesting quotes from the above source:
In otherwords the octane required for optimal operation of your engine might be as much a 10 from the optimal for my (identical) engine.
And:
So you need enough octane to keep from knocking & that is all. It would be nice the the car's knock sensor would light up something on the dash when it kicks in.
The ONR of different engines varies considerably and as much as a 10-octane-number range in ONR can be obtained for vehicles with the same engine model.
And:
Because different grades of gasoline have essentially the same heating value, they all provide the same power in a given engine as long as their antiknock performance meets the engine?s requirement.
