S2000 another idle surge problem
So today I replaced the intake air temp sensor replaced the secondary 02 sensor and removed the defouler. Also hardwired the ballade air pump delete soldered all the wires to make sure everything was connected properly and changed the gasket on the throttle body to make sure there was no vacuum leaks there. I reset the ecu and the vehicle is still having the idle bouncing problem any other ideas?
Two things can cause the idle to hunt up and down on its own. A vac leak after the TB, or the IAC valve is stuck.
Dont think that your brand new IAC can’t be stuck. The only way to check it is split the halves and free use the shaft.
Thanks billman so I went ahead and searched for a vacuum leak this is what I found I attached a clip can that cause the idle hunt? Seems to be air coming from the screw on the throttle cable
I had some loose wires on my map sensor was losing voltage there also I had purchased an aftermarket iacv it was not working properly I replaced with an oem one problem went away
v10killer
10-06-2022 02:32 PM
Metcalfe
06-27-2013 12:34 PM
RobEvo5
12-28-2010 11:09 AM
