shaking right after starting
my04 has ever since i got it a year ago had a slight shake/rattle when it starts, usually the first start of the day, but sometimes during the day also.
it sort of shakes after at the start like it does when we turn it off(i did a search and people said the shaking after turning it off is common)
i was thinking possibly a heat shield rattle or possibly motor mount(to explain the shake).
anyone know for sure or have the same symptoms.
Yep - my '03 does the same. Every S2000 I've driven does the same. Lots of valve spring tension there, I wouldn't worry about it. The car doesn't like running below 1k RPM when it's cold and will let you know about it. I have the TB coolant bypass, and my car is worse with respect to that when it's cold. Everything gets nice and smooth when it's warm though.
i was just reading through the thread on the timing chain tensioner noise and it said something about the sound of cards in the spokes of a bike,...i kinda have that sound at start up with the shaking...... possibly that???
i cant take it to the dealer from them to do nothing about the issue
