Sticky / Rough / Squeaky clutch pedal
#22
Today was the day I actually performed this easy but rewarding maintenance.
Almost no grease found on the clutch fork & rod.
The rod was a little damaged, less then the one in the picture.
May I add that I also polished the other end of the rod.
That's the end that "pivots" in the slave cylinder piston.
For grease on the rod & fork I used a home cooked mixture of a never seeze compound & Molycote.
Needless to say the clutch is working very VERY smoothy now.
IMHO everyone should do this, I'm not sure how much grease Honda puts on during assembly.
And / or how long it lasts.
#23
Make sure you replace your clutch fluid at a regular interval as well. I'm suffering from that now after the new clutch.
Had to replace the master and slave due to what i fugure was rust/contamination since the flud was in long enough to asorb too much water.
#28
Interesting, i was wondering this last week sitting in traffic. Clutch all the way in, slightly pulled up and felt sticky/notch.
I guess i'll do it this weekend when i flush the fluid.
#29
17k miles, I would feel the pedal hard to press it down, but it just started to happen not like this before, any ideas guy? Diifrential fluid at 13k so is the transmission fluid and oil change. shift feel abit sticky too.
