STOCK F20C2 Snapped a Conrod?! Friend's Car - Need Help
Is there any valvetrain damage?
Piston doesn't look to bad but seems to be some marks from the valve. I guess if a valve was dropped there should be much more damage there.
What oil filter was used?
if its a rebuild my bet is he used non FRM compliant pistons, they expanded and wedged in the cylinder cracking the walls, engine still trying to spin snapped the connecting rod.
^^^^^^^^They are A 01 OEM pistons as stamped on the top
With a heavy heart I post this thread. My friend has a 2006 DBW EuroDM spec F20 S2K. He said he installed a rebuilt, 4.7 final drive diff just recently. He bought the old stock diff from me and got the final drive swapped out with a 4.7. Last Saturday after the install he decided to go test it by doing drag racing... he got up to fourth gear after maxing out every gear before that and then noticed a lot of smoke out the back and then the engine switched off...see pics of the carnage below... I'm stumped as to why a stock ECU'd, non-boosted, non modified (except for the new diff) F20 engine with about 95000 miles on the clock and a one owner car (he said he never over-revved it before) would break like this...? Even the sleeve of cylinder four broke?! Oil he has been running is Liqui Moly 10W40 which is a semi synth oil. He runs on Shell V Power 95 octane pump fuel. Looking for advice to help the dude out please?
Crazy damage indeed It's an OEM F20 through and through. Never been opened according to the owner who is the first owner.
Original engine according to him. If it were a rebuild then I wouldn't be surprised by this and your theory could very well be exactly what happened.
Wondering how this could happen to a stock engine. Details are surfacing now though. His wife also drove the car for a while. Not sure if she might have mistakenly filled lower RON fuel during that time for example.
Piston top doesn't show any obvious signs of detonation which could be caused by running lower octane fuel, but check the other pistons as well to make sure.
Some pictures to show how it might look https://www.google.com/search?q=pist...w=1599&bih=824
Lugging the engine (driving constantly in to high gear) is really bad and this might be something an inexperienced driver could have been doing.
Seem a bit far stretched to cause this kind of massive failure though but who knows?
