All of a sudden I'm getting a strong smell of fuel from my car. Car is running well (though I'm obviously not going to push it!), gas cap is tight, exhaust connections appear sound. It seems to be coming from the engine bay -- the dashboard vents seem to blow the fumes strongly, and I got a good whiff when I opened the hood, but a cursory glance didn't reveal anything obvious.
What do you guys think? Fuel injectors? Manifold leak? Something else? Anybody else have this? Thanks, John |
I had this when my fuel pressure guage broken and was leaking fuel out the face of the gauge.
Have you done any fuel related mods? Check the fuel rail tightness as I think this holds the injectors in place, and we removed the fuel rail and injectors to put in the Hondata gasket.
Yeah your fuel rail might need to be tightened down or you might has a small leak in your fuel line. Look under your car and see if there is anything leaking. There is also a black line running to the bottom of your fuel pressure regulator. I would check that hose to see if there are any leaks. I had that fuel smell in my car also but that was after my supercharger was put on with a larger fuel pump.
Originally posted by twohoos All of a sudden I'm getting a strong smell of fuel from my car. Car is running well (though I'm obviously not going to push it!), gas cap is tight, exhaust connections appear sound. It seems to be coming from the engine bay -- the dashboard vents seem to blow the fumes strongly, and I got a good whiff when I opened the hood, but a cursory glance didn't reveal anything obvious. What do you guys think? Fuel injectors? Manifold leak? Something else? Anybody else have this? Thanks, John |
[QUOTE]Originally posted by Prolene
[B]Have you done any fuel related mods? |
A missing oil cap will also provide the hydrocarbon aroma in the cockpit.
I've noticed this on mine a few times also, but usually only when I get out of the car. A strong fuel smell. I just assumed that I overfilled the tank.
[QUOTE]Originally posted by VTECxTurbo
[B] Remember my car has this same problems too? |
[QUOTE]Originally posted by spider
[B] Was it ever fixed? |
