Stumbling at 2000-3000 RPM's
I have 122,XXX miles on my 00 and have noticed that there is a little bit of stumbling/hesitation between 2,000 and 3,000 rpm lately. I don't have any CEL and the car runs great otherwise. I'm contacting the previous owner to see if he changed the spark plugs but according to the manual they're good for 120K. Has anyone else experienced this issue before, was it spark plugs or something else?
Since you hav an '00 make sure that the spark plug update was performed on the car. Early cars (2000 & 2001, maybe more) had under-torqued spark plugs that would rarely cause catastrophic engine failure. The newer plugs have a different gasket and higher torque specification.
Here's a link: https://www.s2ki.com/forums/index.php?showt...0&#entry2050200
I've been happy with the OEM NGKs. Some have reported problems with Bosch and Denso, so I'll stick with OEM. $60 for plugs that last that long is worth it to me.
Investigate the other possible causes of your concern, but I'd replace the plugs too with that many miles.
The car is stock with just the Comptech icebox and 4-1 header. I'll do the plugs first and move down the list. Is the TPS sensor a common failure? It doesn't hestitate or run weird above 3000 rpms and pull strong through the rev range. Also getting normal gas mileage.
