TB Sticky pedal feel
but only when the engine is on? The notchy feel is the top of the travel and is now annoying!. I have checked and cleaned the TB, Throttle cable is within spec 4-6mm lubed and cleaned all components from the pedal up to the TB.
Any thoughts? as I say kill the engine and the action is free and fine , start the car and the stickiness appears. I just can
Maybe that has its influence on the throttle valve and the shaft?
In the service manual are no other solutions for a "worn" TB then to replace
Do you have cruise control?
If so, that's another cable.
