tct or valve adjustment? cylinder 4 misfire
Did you notice if the valve gaps tight before your adjustment?
I can't tell from the pictures whether the retainers are showing any signs of cracking. The cracks generally appear on the underside. From the topside you are looking to see if the keepers are sunken into the retainers a bit more than normal. You can't see them in the pictures you posted because the rocker is obscuring the view. If they are sunken in, that is a sign of cracks that will be apparent on the underside of the retainer if you remove the retainer. If not sunken, then you are ok.
Do you have any reason to believe the engine was mechanically over revd?
Could a vacuum leak or dirty fuel filter cause his misfire?
To the OP have you ever run good quality injector/fuel system cleaner? Try that if you haven't already.
Personally i havent overevved the car i dont know about previous owner. When i did the valve adjustment there were only a few that were a bit tight n some a little loose nothing seemed out of place tho
The components that are isolated to one cylinder starting from the top down are/
ECU
engine harness
coil pack
spark plug
fuel injector
valves
cylinder
If injectors are really dirty, even sending them out for ultrasonic cleaning often only helps temporarily. It seems there is a point of no return. So its interesting that Techron treatment seemed to help, but only temporarily.
Perhaps its a sign of a too far gone injector.
No not likely, since he is only getting a misfire on one cylinder. A dirty fuel filter sock would cause fuel starvation to all cylinders, and it would have to be pretty clogged, not likely in my experience with this car to ever have that issue anyway, and a vac leak would also not be isolated to one cylinder.
ECU
engine harness
coil pack
spark plug
fuel injector
valves
cylinder
ECU
engine harness
coil pack
spark plug
fuel injector
valves
cylinder
As for the coil packs, typically on our cars cylinder 3's coil pack gets drenched in oil due to the spark plug seals not stopping oil from getting in. they get hard and brittle over the years. Replacing them solves the issue preventing misfires caused by that but if the pack is too far gone as a result of oil soak then it has to be replaced in addition to the seals in the valve cover being replaced.
i did the adjustment myself did .10 (0.010 I assume?) on the exhaust side and .08 (0.008?) on the intake side car runs perfectly fine
-- Chuck
I hope I understood that correctly, because that is how I have my ap1 set. Also, OPs setting is within OEM spec, and so it does not explain his symptoms.
