TCT or VTEC solenoid gasket please help
Old 08-06-2018, 08:49 PM
Pudge31's Avatar
Default TCT or VTEC solenoid gasket please help
Sorry I know I'm beating a dead horse with this one but I just needed some reassurance on it before I ended up buying a new tct for no reason.
I've been having this leak for a while and tried to locate the source before doing anything and I just looked into it after the car sat for 3 days. Cleaned everything off before letting it sit and got these pictures today. Solenoid sensor is always soaked which leads me to believe it's the gasket but it was replaced 3 months ago so I'm at a loss for words. Top gasket is clean as a whistle. Is it possible for the o rings around the tct to leak? Any help would be greatly appreciated! I should also add that I do get no rattle or slapping noise from the tct at.
Old 08-06-2018, 10:48 PM
RolanTHUNDER's Avatar
That must be TCT seal related. You'll have to pull it to inspect.
Old 08-08-2018, 01:35 AM
Originally Posted by Deckoz
Looks like the oil pressure switch O-Ring on the VTEC solenoid..... Look up... There is oil higher then the TCT..
Well spotted
Old 08-14-2018, 02:07 AM
Lol hey could be both? I'm in the middle of rebuilding the TCT again -_- I literally just replaced it with OEM a month and a half ago. And it's leaking...
If OP needs it.
Oil switch O-Ring
Tct orings
Could be both
Odd that even after you replaced your TCT and it's leaking...
Old 08-16-2018, 11:13 PM
I rebuilt it. Anyway, the service cap bolts we're loose, didn't check their torque as it came assembled. Never had an "assembly" come from Honda with undertorqued bolts, so didn't think that was the culprit. I pulled the TCT just to make sure I didn't pinch the O-Rings a anyway. Fine now
wow. Glad you sorted it out easily. I'll pull my VTEC solenoid to check the condition of the gasket. Will probably just replace mine as well
Old 08-20-2018, 10:28 PM
I mean the service cap bolts of the TCT(triangle gasket)
Ah I see.
MB
09-10-2016 11:50 PM
NickGDB
08-17-2014 03:54 PM
jomaniofficial
11-24-2013 10:06 PM
lopez14
11-28-2012 05:12 PM
Quick Reply: TCT or VTEC solenoid gasket please help
