Temp gauge doesn't work
Old 08-17-2011, 05:57 PM
fernando.'s Avatar
Default Temp gauge doesn't work
I just drove my S2 home tonight and I must say I'm super impressed by this car, haha. The engine was swapped for the same F20c due to a miss-shift, the car runs amazing but the temp gauge doesn't work. I drove the car 30 miles home and the gauge only had one bar the whole drive home. Any ideas what this could be?
Old 08-17-2011, 06:18 PM
bbss2k's Avatar
I had the same issue and ironically, my engine was replaced for the same reason before I bought the car. Replace the temp sensor. It's on the back of the intake manifold. Got mine from Honda for $25
Old 08-17-2011, 06:46 PM
fernando.'s Avatar
That what I figured it might be, maybe they hit the sensor off the firewall or something and damaged it.
Old 08-19-2011, 12:10 PM
fernando.'s Avatar
Ok, well here they want $60 for the sensor so before I go and replace it I just want to make sure that is the problem. I used a volt meter and the plug had 4.97v which from what I'm told is normal. I asked at Honda and they told me "Well if the ECT is pooched then the motor will run like shit because the ECU won't know the temp of the motor and it'll keep it in open loop and also throw a code" ...this true?
Old 08-19-2011, 01:55 PM
Stratocaster's Avatar
The temp effects the tune. So lacking a temp sensor will be a problem.
Old 08-19-2011, 02:27 PM
fernando.'s Avatar
I'm stumped, there's 4.97v going to the sensor, I have no CEL, I'm not 100% sure if the fans are kicking in though. Unless this is an issue between the ECU and the cluster...
Old 08-19-2011, 02:43 PM
Banned
vividracing.com's Avatar
Are you testing the sensor at the ECU, or at the sensor? Test it at the ECU, so you know what the signal looks like when it gets to the ECU. You might be getting a bad signal @ the ECU, but a great signal @ the sensor.
Old 08-19-2011, 03:32 PM
fernando.'s Avatar
Nevermind, figured it out. Wire was pulled out at the ECU plug.
Old 08-19-2011, 04:14 PM
lilsharky's Avatar
do you know the P/N to the sensor? Was it hard to replace?
Old 08-20-2011, 12:48 PM
fernando.'s Avatar
The problem wasn't the sensor. I pulled off the ECU kick panel and found the yellow/green signal wire for the ECT to the cluster was pulled out of the ECU plug.
Quick Reply: Temp gauge doesn't work
