test pipe install
Old Sep 14, 2008 | 08:53 AM
s2ktimmy's Avatar
Default test pipe install
HI everyone i put on my test pipe and got a cel i have the anti-fouler and still got it i even added a longer fouler and it still came on anything i can do to make it turn off and if it on the car can go into limp mode right?
Old Sep 14, 2008 | 10:08 AM
em ekohc's Avatar
Put the cat back on
Old Sep 14, 2008 | 12:03 PM
EVAN&MONICA's Avatar
Reset your ECU if you havent already
Old Sep 14, 2008 | 04:55 PM
s2ktimmy's Avatar
i did re-set it i want to keep the cat off does this only happen on 02
Old Sep 14, 2008 | 05:08 PM
Harpoon's Avatar
What, specifically, are you using for an antifouler?
Old Sep 14, 2008 | 05:45 PM
~blacks2k~'s Avatar
No, there is no such thing as limp mode. The car will not perform any differently with the CEL on.
Old Sep 14, 2008 | 05:56 PM
9kFever's Avatar
You should have no problem with the right defouler. Pull the code. Sure you didn't do an intake or anything at the same time?
Old Sep 14, 2008 | 07:15 PM
s2ktimmy's Avatar
I made the custom one and i got one ebay i did a intake but had no cel at all for about 500 miles and i got a cel after i did the testpipe about 30 miles on it ill pull the code tommrow any one else have any problem running cat-less
Old Sep 14, 2008 | 07:16 PM
s2ktimmy's Avatar
so if the light on there will be no diffrence in proformance at all i still going to get the code pulled but there is no limp mode
Old Sep 14, 2008 | 07:19 PM
S2KVITO's Avatar
Yeah the CEL is just warning you something "may" be wrong for ppl that modify there car it's bound to come on somtime esp if your going catless. I'm pretty sure it's that intake that's probably causing the CEL best way to find out it's not the TP is install the stock air box and run the TP and Anti-Fouler.
