Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Thanks to Billman brake pedal travel.
Notices
Old 10-04-2017, 04:08 AM
Liked 1 Time in 1 Post
Default Thanks to Billman brake pedal travel.
hi all, i dont own a honda but drive a toyota celica year 2000. thought i would sign up to give thanks to billman which iv read on here advises with brake bleeding issue and long pedal travel to wedge the brake pedal overnight. so i thought i would give it a try since changing my calipers and hoses ended up with a pedal to the floor before any brake affect was felt.
after wedging the brake pedal overnight the pedal travel was halved. its considerably better now and needs about 1cm travel and i can feel the brakes bite.
i dont know how or why this method works but its worked well for me so i thought i would sign up and say thanks.
slybunda is offline
Old 10-04-2017, 04:26 AM
freq's Avatar
Liked 135 Times in 122 Posts
Pics of Celica or it never happened.
freq is offline
Old 10-04-2017, 04:34 AM
celica is on the left.
slybunda is offline
The following users liked this post: slybunda
freq (10-04-2017)
Old 10-04-2017, 05:45 AM
Billman250's Avatar
Liked 238 Times in 192 Posts
This method was taught to me by an 80yr old gentleman at the time, over 25 years ago. He was the owner of a major truck and machine company out here.
Billman250 is online now
The following 2 users liked this post by Billman250:
JoePhotographer (10-04-2017), slybunda (10-06-2017)
Old 10-04-2017, 07:16 AM
Why and how does this method work?
slybunda is offline
Old 10-04-2017, 07:44 AM
Liked 225 Times in 197 Posts
There is a huge amount of psi in a hydraulic brake system when you press the pedal hard. All that pressure in the fluid over time more forcefully incents the air bubbles to move their way up to the mc. Its kinda like it squeezes the air up out of the system.
Then when you finally release the pedal, the air can escape into resevoir.
Its a trick I've been using for a really long time as well. It works for clutch pedal too, just not as well, since the psi is limited by how much the pressure plate pushes back against the hydraulics.
Car Analogy is offline
Old 10-04-2017, 09:51 AM
Billman250's Avatar
In short, it allows large air bubbles to break into tiny air bubbles, and make their way up to the resovior where the exit the system.
Old 10-04-2017, 11:33 AM
when cars are new from factory what sort of method do they use to fill the brake fluid? do they use 2 man method on every car?
slybunda is offline
Old 10-04-2017, 03:45 PM
Liked 31 Times in 29 Posts
using my crystal ball, i see the factory using a pressurized vacuum system to fill the brake fluid. i most definitely highly doubt they use a 2 man method at the factory - talk about a bottleneck in the assembly line
jyeung528 is offline
Old 10-04-2017, 05:10 PM
darcyw's Avatar
Liked 68 Times in 62 Posts
you know, i've always wondered this.
darcy
darcyw is offline
Quick Reply: Thanks to Billman brake pedal travel.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
