Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Thanks to Billman brake pedal travel.
Old 10-06-2017, 01:26 PM
  #21
Liked 128 Times in 117 Posts
Originally Posted by Langelo DeMysterioso View Post
Do you need to disconnect the battery?! Yes??
I need to install my ABS unit and I've been putting it off.
Your brake lights will be on all night if the battery is left connected.
Maybe pull the brake light fuse if you're worried about losing radio settings.
B serious is online now
Old 10-06-2017, 01:30 PM
  #22
Liked 0 Times in 0 Posts
Ok so I just installed s.s. lines,pads and bleed the brakes. Felt somewhat spongy not as I would like them to feel. Went ahead and pinned the brake pedal with a piece of 4x4 and left for over 24 hours. Also did as billman said and disconnected the battery to prevent the battery from dying. Just removed the wood today and brakes feel 100 times better. Thanks for the info really helped.
Rayz_S2K is offline
Old 10-06-2017, 03:32 PM
  #23
Liked 229 Times in 200 Posts
Amazon sells a tool that clamps to steering wheel, to hold brake pedal down. For service purposes. Its a sort of adjustable length rod.
A 2x4 works just as well. Brace against seat (with another 2x4 across base of seat to spread the load), and adjust seat fwd as needed to depress brake pedal.
Car Analogy is offline
Old 05-18-2018, 05:47 AM
  #24
Originally Posted by Billman250 View Post
This method was taught to me by an 80yr old gentleman at the time, over 25 years ago. He was the owner of a major truck and machine company out here.
Worked amazing! Forgot to disconnect battery though...so now my battery is being charged.
Thanks Billman!
S2K4WIN is offline
Old 12-12-2018, 09:45 PM
  #25
Liked 8 Times in 5 Posts
need to try billman's wedge method, do you guys start the engine first, use the power assist to wedge the brake pedal hard and then shut off the engine and disconnect battery?
i'm just worried using power assist would create too much brake pressure for sitting 24 hours.
AlpineFD is offline
Old 12-13-2018, 05:26 AM
  #26
nubbel's Avatar
Liked 9 Times in 7 Posts
Yes, while the engine is running give it two/three slow pumps then hold down the pedal with moderate force, shut off the engine and wedge it down.
The vacuum line to the break booster does have a one-way-valve which should allow for one assisted brake pedal press after the engine has been shut off, though.
Also, I wouldn't disconnect the battery as it resets your stereo and your ECU - idle relearn procedure required afterwards.
Just disconnect the switch above your brake pedal and your brake lights are gone
nubbel is offline
Old 12-15-2018, 09:02 AM
  #27
i was kind of skeptical at first, but this worked ! Wedging it overnight firmed up the pressure point of my brake pedal quite a bit.
Thank you billman !!
Amazon Amazon
i used this tool to wedge it
AlpineFD is offline
Old 12-15-2018, 09:44 AM
  #28
NNY S2k's Avatar
Liked 68 Times in 63 Posts
Thanks to Billman I've done this before with excellent results. I used an extendable snow brush to wedge the pedal.
Levi
NNY S2k is offline
Old 03-12-2019, 03:44 PM
  #29
E-brake on or off for this method or doesn't matter?
iam_ultrasonic is offline
Old 03-12-2019, 05:08 PM
  #30
It shouldn't matter. But why not just leave e brake off? The brakes will be on, car won't move. Put in gear too if you're worried.
If your only overnight parking is on a hill, make it nose up. Make it easier for air to get out mc.
The following users liked this post: Car Analogy
iam_ultrasonic (03-13-2019)
trackrabbit21
08-11-2015 11:14 AM
LoneStarS30Z
01-06-2014 09:09 PM
04S2kSS
12-05-2010 06:41 PM
plokivos
02-07-2008 05:21 AM
goldingt
10-17-2007 01:12 PM
Quick Reply: Thanks to Billman brake pedal travel.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
