Originally Posted by RolanTHUNDER
(Post 24851885)
Can this sensor prevent the car from starting. I think that's my issue.
Correct me if I'm wrong, but I'm assuming it'd be easy to rule out one of those two hypothesis. With a bad crank position sensor, wouldn't you get crank but no start, where with an issue with clutch interlock you'd get no crank at all?
Crank being defined as push start button, and engine goes roundy round, tryin to start, but never does. No crank being push button and nuthin happens at all. |
Originally Posted by Slowcrash_101
(Post 24851890)
Not the clutch interlock switch?
I was referring to the CKP. Can that cause no start or more accurately, failed start? Just as it attempts to start from cranking it stumbles out and the process repeats...? |
Originally Posted by Car Analogy
(Post 24851915)
