Is there something wrong with my clutch?
#21
No I haven't replaced the tranny, just everything in between.
Flywheel, pilot bearing, friction disc, pressure plate, release bearing, release bearing guide, fork spring and the most important thing, urea grease.
#22
Ok so the parts I didn’t replace were the Flywheel, pilot bearing and fork spring. When you took your apart, did you see any noticeable damage to these parts? Trying to determine if it’s easy to tell if they are faulty when replacing the clutch.
Thanks again for your help.
#23
You did mention clutch pilot bearing so you got that one covered.
The fork spring just keeps the fork from falling out so that should not be your problem either.
