Throttle cable to long
i just installed my ballade throttle body and I had to adjust the throttle cable to the point to where it has no more adjustment left. The cable has no slack in it which I like but what do I do in the future if the cable stretches and I need to tension it more
i can post a picture if u are confused on what I mean
I thought the ballade throttle body was just a bored out stock one? How many miles on your stock cable maybe it is streched. Maybe replace it now. Btw hows the throttle body notice a difference? Plan on getting a tune or no...
No the Ballade is not bored out OEM TB, just look at a picture they don't even look the same. My cable was well within the adjustment limits when using the OEM TB.
The throttle cable has to have a tiny amount of slack in it.
The cam wheel is smaller on the Ballade unit, I just unbolted the bracket for the throttle cable, drilled the holes out a little larger and moved it down and back a bit to create a larger gap. I was not impressed that they didn't make any mention of this.
