Throttle Position Sensor signal DBW
Hi..
I'm trying to guess where to find the TPS wire on a DBW S2000 (MY08) The sensor is not located where the non-DBW sensor is located.. but I assume that somehow the TPS information is needed and that the signal should be available somewhere :) What I need is a 0..5V signal (5V full open and 0 full closed for example) I need to it to tap it into a Innovate LMA-3 Interface. Any help would be appreciated. I have tried to used the search but I did not find a direct answer to it. Thanks! |
I have "found" this sensor
http://www.hondapartsnow.com/diagram...sor-462529.png it's not really a TPS but a "accelerator pedal position sensor", so I suppose that this sensor is used by the ECU to decide how much to open or to close the throttle body.. The TB itself must have somewhere a wire that indicates how much the TB should be opened or closed.. (that's what I am searching) But I don't have any DBW TB wiring diagram (or the accelerator pedal sensor).. does someone have it? (Helm's manual maybe?) |
i'm not sure what you mena but at those pictures this black thing wi the sicket is throttle motor:
http://www.risingsunperformance.nl/m...09ca3nw35q.jpg http://image.nengun.com/catalogue/or...ottle_body.png maybe you can tap it it. |
yeah.. but which of each of the 6 wires does what? :D
(i need the pinout diagram...) |
later i will look at the ETM and tell you.
(i need the pinout diagram...) Thats a start. J |
