Time for a new belt?
I have a 2004 with 80k miles. I was planning on replacing the serpentine drive belt but upon closer inspection the edge of the indicator isn’t beyond the edge of the tensioner base.
Given the age, should I replace it anyways?
If it were me, I'd replace it. Rubber compound lose their elasticity, with age and heat. Use OEM.
Cool! Original owner's club member!
Looks and should be good for another 30k miles. Doesn't hurt to change it though. I recommend a Gates belt
According to the marks, you are out of range. The “good belt” zone is the first third of that indicator block that is sitting lower.
With that, the indicator is not an accurate way to judge condition anyway. Visual inspection is the way to go, dont use the indicator solely.
Cossa (10-05-2018)
In comparison to auto part store belts, the OEM belt quality is off the chart. Can literally last 4 times as long. Even ones with over 100k on them show no cracks.
Is there any reason to replace an original low mileage belt that looks good and meets specs just because its 16 years old?
