transmission upgrade
i have an '02 s2k that is s/c and only has 38,000 on it and i was driving the car yesterday when i shifted from 1st to 2nd something poped and continuely chattered like metal on metal. I stoped the car and was looking at it while i was waiting on the tow truck and was thrown for a loop. I could have the clutch pedal pressed in and the motor would start fine no noises then as soon as i let it out the chatter started again i should describe it as like metal slapping metal. I tried it in every gear and it did this.
now that i got that out of the way, I was wondering if anybody had any ideas of any kind of trans upgrades for the car. or suggestions on what might be wrong i am currently in the process of pulling it apart to try to figure it out. any help would be appreciated James |
Definitely a problem with the tranny. You hear no noise when the clutch pedal is depressed because the tranny is not connected to the engine, and thus not spinning. It could be a number of things, and I'm no expert so I won't try to give any insights. If something is irrepealably damaged however, I think a logical step would be to get an AP2 tranny.
are they a stronger tranny than the AP1's
Sounds more like a diff failure to me.
when i was listening to it i didnt hear any noise coming from the rear. and it makes the noise sitting still butt thanks for the suggestion.
Ok I
sorry about that i just ment it made me confused when i said it thru me for a loop. and hopefully i dont find out it is the tranny.
[QUOTE=SC-S2000,Jan 18 2006, 07:08 PM]sorry about that i just ment it made me confused when i said it thru me for a loop.
I had a similar problema while ago with my integra. Awful sound coming from the tranny being engaged, thought it was the gears, but I could engage every gear and then thought it might be the final drive, but there was no metal in the oil when I drained it. Turned out to be the splines on the clutchdisk had taken a crap. The heattreat on the part was done wrong and I had gone over a little bump and caught some air. On the impact the input shaft had started to shear the teeth off.
Hopefully it will be that. You should drain your tranny fluid and diff fluid to see if there are metal flakese, if not most likely it will be the clutch disk. |
