Trying to figure whats wrong, help needed!
Old 05-26-2017, 01:02 AM
BoostAlong's Avatar
Originally Posted by s2000Junky
Ahhh, I think you have bigger issues. But yeah, hope the bearing in the turbo didnt get washed as well. Looking at the mud soup and what looks like water droplets mixed in, my first though is blown HG. But im not as privy to what E85 looks like mixed in with engine oil. What im seeing and hearing so far though, you have engine damage, with best case scenario being a HG, and worst your cyl #1 is down and possibly damage to your turbo as well. It could just be blow by from your cylinder thats down though, and turbo is ok. You wont really know until you clean it up and start examining things.
yea thats what ive been thinking that number 1 is a goner but just praying its a valve seal that went out...and i was having alot of smoke coming out of my breather from valve cover. Would that point out any possibility of it being something else?
Old 05-26-2017, 07:19 AM
s2000Junky's Avatar
Smoke out of the breather means piston rings. Its blow by gases not being combusted, slipping past the rings. Again probably broken piston ring land or severe cylinder scoring in general.
Old 05-26-2017, 08:08 AM
BoostAlong's Avatar
thank you ill most likely justnlook inti a rebuild
Old 05-26-2017, 08:53 AM
jwzimm's Avatar
What I'm not understanding is, oil in wastegate so pretty much i got oil in my turbo mani. Wouldnt that oil get sucked into turbo blowing it back into pipe? Maybe im just not making any sense. Or im just over thinking atm
A turbocharger is a two closed-system device. There is no physical way for fluid or gases from the hot side (exhaust driven turbine) to migrate to the cold side (turbine driven compressor).
Honestly is sounds like you either detonated cylinder #1 and the piston ring lands are shot (and, by proxy the cylinder walls) or your blew the head gasket. Or both.
You may want to post some details about your build. What turbo setup are you using? What are you using for boost control and engine management?
Old 05-26-2017, 09:01 AM
BoostAlong's Avatar
yeah most likely thats what happen cylinder 1 goner
Old 05-31-2017, 12:48 PM
jyeung528's Avatar
in for updates.
Moddiction
10-02-2015 05:47 PM
Wellwibb
08-02-2013 12:28 PM
hieus2k
Jacksonville
16
02-21-2013 08:40 AM
05TurboS2k
02-17-2012 02:34 PM
crank
06-21-2010 04:25 PM
Quick Reply: Trying to figure whats wrong, help needed!
