exploring upgrading the ABS module from AP1 to AP2v1
It is the dead of winter and all I want to do is drive my s2000 and improve it... but I keep it hibernating until the end of April.
Anyway, I recently stumbled onto this s2000 review This piqued my interest as it provided more substantive hands-on insight into the 04-05 ABS improvements than anything I had seen before. Until I went looking and found this: The ABS system has been improved through the use of split-regulation yaw-control logic for improved stability on split-μμ surfaces when the ABS is triggered. Furthermore, though more powerful than before, the system (consisting of the CPU and modulator) has been downsized for both precious space and weight savings. Anti-Lock Brake System (ABS) The anti-lock braking system (ABS) is a compact type that incorporates the solenoid valve, motor and ECU into the modulator body, thereby saving both space and weight. The ABS system is a four-sensor, three-channel system with a speed sensor located at each wheel. There is a separate channel for each front wheel and the rear wheels share a common third channel. This is a "select-low" system, meaning the system controls both rear-wheel slave cylinders together when it senses incipient wheel lockup in either wheel. The system uses the memory capacity of the system's Electronic Control Unit (ECU) and allows the system to better estimate vehicle speed, which gives it better control in the lower-slip range. This contributes to superior braking efficiency and stability. For the 2004 S2000, with improvement of both hardware and software in the compact ABS modulator, memory capacity has increased and new program logic has been added which enhances braking efficiency and reduces the weight of the system. https://cimg6.ibsrv.net/gimg/www.s2k...c06e8c11b3.png when compared to the AP1 25P connector: https://cimg1.ibsrv.net/gimg/www.s2k...a6bc33a9e0.png I then did some searching on s2ki and found this post that said: It looks like the modulators are a straight swap from AP1 to 04-05 AP2. 06-09 AP2 has VSA and that's way more complex and involved to swap in. From an 01 to an 05 spec, the modulator uses the same pin out for the coupler and the same wheel speed processing speed (they're common from 00-05). As long as the ports are the same, which I didn't check, you should just be able to bolt in the 05 modulator and connect the brake lines. It really looks like the worst part is going to be preventing air into the system when swapping the ABS module out. I may be lazy and just get a Honda mechanic to do it for me (brakes are my major s2000/car wrenching blind-spot!) Anyone aware of something I'm missing that makes this 02 to 04 ABS module upgrade a non-starter? |
I don't have any answers for you, but great post. I'm subscribing and eagerly waiting responses (and follow-up to your research). :tipwink:
Wow, really cool.....From what I gathered it seems that the processing capabilities of the ABS module internally are enhanced both logic-wise as well as mechanically, but electrically they're the same.
I did some digging myself and the pinouts for both connectors are exactly the same, even though there's extra pins on there, your suspicions were confirmed that they're not used. I used this as reference....This should definitely be a sticky all over this site, it has basically everything you need regarding s2000 information, and then some. S2000.club [Your Honda S2000 Resource] So, digging through the 2000-2003 and 00-08 service manuals, starting with the 2000-2003 service manual, go to section 19-39 & 19-40, shows the 25 pin connector and all related pinouts (upside-down oriented to how you have it in your pics). Next, go to page 19-31 in the 2000-2008 manual. It lists the ABS Components index for ('00-05 models) and includes the circuit diagram and troubleshooting etc. under that, which to me means that they must share the exact same pinout, and like you said before, the logic processing of the unit has been enhanced internally and mechanically, while still remaining the same in terms of electrical operation. OEMs have extra pins all the time that aren't used depending on the domestic market of the vehicle, some features are added or removed, but to save on cost and simplify part numbers, sometimes wire harnesses and components are pinned to accommodate accessories/features that aren't present and/or supported in the vehicle depending on region, trim, etc. Anyways, going to 19-39 & 19-40 in the 2000-2008 manual it lists the exact same pinouts as the 00-03 manual for the 25 pin ABS connector. Pin 1: Present, but not used (AP1 & AP2) Pin 2: Front right wheel sensor negative (-) Pin 3: Front left wheel sensor positive (+) Pin 4: Brake switch stop signal Pin 5: Rear left wheel sensor positive (+) Pin 6: Rear right wheel sensor negative (-) Pin 7: ABS light warning indicator Pin 8: Failsafe relay power (+) Pin 9: Motor relay power (+) Pin 10: Data link for Honda PGM tester Pin 11: Present, but not used (AP1 & AP2) Pin 12: Front left wheel sensor negative (-) Pin 13: Service check connector signal detection Pin 14: Rear left wheel sensor negative (-) Pin 15: Rear right wheel sensor positive (+) Pin 16: Ignition (powers the whole system) Pin 17: Present, but not used (AP1 & AP2) Pin 18: Front right wheel sensor positive (+) Pin 19: Present, but not used (AP1 & AP2) Pin 20: Present, but not used (AP1 & AP2) Pin 21: Only present on AP2, not used 04-09 Pin 22: Only present on AP2, not used 04-09 Pin 23: Only present on AP2, not used 04-09 Pin 24: Ground Pin 25: Ground Here's your picture of the AP1 connector with all pins identified in relation to the diagram if orientations lined up, the ones not used have an "x" notation, and even though pins 21-23 are present on an AP2 connector, they're still not used as well. https://cimg7.ibsrv.net/gimg/www.s2k...05a549589b.png It seems like even the 04-09 models don't utilize those pins either, if you go to page 19-67 in the 2000-2008 manual I'm assuming it's listing all of the components again, with the addition of the VSA system for the 06-08, but it again lists the ABS Components for ('00-05) and refers you back to page 19-31 in the 2000-2008 manual, which signals to me that all model year AP2s share the same components mechanically regarding the ABS module, as well as with the AP1. I'm assuming they upgraded the ABS modulator yet again in 2006-2009, but probably changed the computer logic to work in conjunction with the newly added VSA system. From what I can gather the VSA system receives and transmits data to and from the ABS module, but I don't think there's any additional components or connections within the ABS system between 00-09, just instead the method of operation (00-05 no VSA logic, 06-09 VSA logic) Unfortunately I don't have any further information regarding the unused pins except by what the service manuals tell me. But regardless, excluding the 06-09s which are indicated to share the same components (albeit with different part numbers for the ABS modules (00-03, 04-05, 06-09) and some hard lines / brackets (04-09) they all share the same pinout and function for ALL model years. Given that the 00-05 models still operate without any additional computer nannies and share the same pinout and layout, I can only concur that the changes that you mentioned are indeed true and are simply limited to how the module operates and the logic behind how it processes information ie. revised from the 00-03 models. The AP2 seemed to take a lot of lessons from the AP1 in terms of ways to operate not only more predictably, but more efficiently. With that said, I'd say that with the improved operation function and logic this will definitely be a bolt-in upgrade. How noticeable? Who actually knows. Worth a shot though....the only real way to gain real-world results would be to do back-to-back testing between modules and in conditions where any improvements and/or changes in braking characteristics would go noticed, so it would have to be on the same track or closed circuit with an experienced driver. All in all super interesting....sorry for the long post, I've got some time on my hands at work tonight, and stuff like this is definitely intriguing, especially because there's quite a few parts that people swap over from the AP2 to the AP1 as a straight upgrade, this may be yet another thing worth looking into! I decided to say screw it and ordered myself a setup as well. Got it for $50 shipped off of ebay, and it includes the module, bracket, master cylinder, and the 2 hard lines that you mentioned that are different from the AP1 still attached. Looking at the parts diagrams between the 02 and 05, the master cylinders share the same part number, so it just seems like the ABS module is mounted slightly different like you said, but the hard mounting points for the bracket to the chassis are the same it seems. From the looks of it, the 04 and up have a revised mounting setup that include much larger rubber dampers mounting the module to the bracket, and 3 of them as opposed to only 2 for the AP1. For under 100 bucks overall it's worth checking into on a weekend I'd say! |
I'm just curious what you find lacking with the ap1 abs system? |
Originally Posted by Kyle
(Post 24563726)
... All in all super interesting.... ... For under 100 bucks overall it's worth checking into on a weekend I'd say! Hopefully this ABS upgrade will pair well with my AEM Infinity that has Traction Control configured (the AEM traction control reduces timing and causes the engine to back off if it feels wheel slip.. as determined by wheel speed difference between rear wheels' VSS and the front ABS wheel speed sensor).
Originally Posted by starchland
(Post 24563749)
I'm just curious what you find lacking with the ap1 abs system? In short: I have a 2.4L with custom intake, IM, exhaust header, exhaust and differential. I'm just trying to get the best experience out of the platform, improving safety if/when driving at the limit. |
Originally Posted by snitm
(Post 24564016)
Thanks so much for looking through all of your resources to confirm my suspicion/hope! Yeah, I was very happy to find that the ABS module so cheap. My line of thinking on it is: Honda engineers put a lot of time and effort into these upgrades, so if it is basically just a drop in to upgrade then it is totally worth it to try.
Hopefully this ABS upgrade will pair well with my AEM Infinity that has Traction Control configured (the AEM traction control reduces timing and causes the engine to back off if it feels wheel slip.. as determined by wheel speed difference between rear wheels' VSS and the front ABS wheel speed sensor). No problem, thanks for putting that out there! In all of my research I haven't seen any mention of this before, so it's pretty cool that there's something new to potentially be explored. Eager to hear your feedback when and if you go about doing the module swap. In my excitement I grabbed one, and I may go ahead and install it myself one of these days, but favorably I'd like more data and feedback first, aka someone else does all of the work and becomes the guinea pig for me :P Hoping some more esteemed members of the community catch wind of this thread and can come in here to chime in on this potential upgrade. I'd be interested to hear the opinions of others on this, and how it could realistically affect the braking characteristics for the better in real-world scenarios. |
I know this is asking too much, but with how thorough both of you posters have been... It would be great if we could get some real-world, same-day back-to-back testing of the AP1 ABS prior to swapping in the AP2 ABS.
I'm not even sure what you'd test -- stopping distance for a full-on panic stop, pedal feel (?), and perhaps the feel of trail-braking? Tall order, for sure. Maybe we can get SaveGeese's attention and get him to make a video :) |
Originally Posted by HarryD
(Post 24564108)
I'm not even sure what you'd test -- stopping distance for a full-on panic stop, pedal feel (?), and perhaps the feel of trail-braking? Tall order, for sure. Maybe we can get SaveGeese's attention and get him to make a video :) If anyone is down for that reach out, I'd be more than happy to facilitate it and would love some input and data. |
Have you managed to fit the pump yet?
Mine has failed so looking for a replacement (03) but if this fits with the new brakets and some new lines then i may well go this route! |
Originally Posted by johnckeen
(Post 24585187)
