Valve gasket and valve adjustment
Hello All,
I have MY02 S2k with ~100k miles. I have never changed the gasket and it needs to be replaced as there is a leak. I have all the parts and I was quoted $215 for labor.
I watched some videos on how to change the gasket and it doesn't seem that difficult. I also wanted to respray my value cover as it's chipping.
My question is do I need to get my values adjusted or can I just change the gasket myself?
Thanks!
Thanks!
No reason you HAVE to adjust the valves when removing the valve cover, it's nice to do since you're already in there though, especially at 100k miles. I adjusted mine at ~122k and they were out of tolerance. To give you some piece of mind you should probably check them though since there's nothing really else to disassemble. If you're not comfortable with shims or doing the valve adjustment maybe you should have someone do it if you don't have record of the last time.
After doing this myself recently make sure to be VERY careful when installing the valve cover back on with the new spark plug tube seals. I ruined the first set because I pushed them into the valve cover all of the way and they didn't sit around the tubes correctly. Don't seat them in all the way into the valve cover, maybe take a photo of how far they were installed before replacing the old ones.
From watching the YouTube videos I'm able to change the VC gasket. Should I get the valves adjusted too? What other maintenance would you recommend?
Thanks
When replacing the valve cover gasket, do you pre oil it like you do for oil filter? How about using gasket maker like hondabond?
edit: seems like the s2k valve cover is flat and doesn't have the cam humps, so sealant isn't required? but i've heard you should dab a bit to where the timing chain cover meets
@Billman250
@Billman250
Just buy the proper gasket. Clean the groove where the gasket goes and put it in. The only reason you put oil on the oil filter gasket is so you can turn it tight and let the seal slide around the place it meets the block. Valve cover gasket just plops in there.
There's more than just the main gasket. Each spark plug hole gets one as well as those on the mounting bolts.
Valve adjustment requires a cold engine (under 100°F) and that takes hours to achieve after driving the car. Simple, rewarding, tedious task. Tools are no more than $25.
-- Chuck
-- Chuck
@Billman250
@Billman250
DO a retainer check/valve adjustment while you're in there. I've done over a dozen VA- the first took me like all day (6 hours start to finish). Now, takes about 90 minutes maybe.
darcy
