Vibration under acceleration wont go away after new half shafts install
I have done research on this subject in S2KI forums on different threads.
I have a rear drive-train vibration that comes on over 40 mph and it is mainly felt under acceleration and more so with acceleration out of fast corners. This subject seems to be resolved for everyone by switching the CV cups from left to right, but instead of doing this i purchased new half shafts left and right, and the vibration remains if not worse. I justt had the wheels and tires balance too with no change. Rear tires are Toyo and they are new. The AP1 rear has: BLOX axle spacers installed from previous owner. The car is lowered with Tein springs. Has LSD clutch pack differential. Should i take the axle spacers off? Could this be a bearing as sometimes i hear a high pitched wine under load? I read everywhere this vibration under load most likely is the CV's pitting but it's doing the same thing with NEW half shafts so what is going on? Please help, this community has been awesome in helping me investigate other issues, i have never needed to post until now. Thanks :tiphat: |
Are the half shafts oem? Many have reported this issue with inexpensive off the shelf parts store options.
Could also be a diff or even trans issue. You can try removing the half shaft spacers to at least get that out of the way as process of elimination. Hopefully the guy who owned the car before you had enough sense to buy the two piece kind so you don't have to go pulling your shaft again. |
Originally Posted by s2000Junky
(Post 24425802)
Could also be a diff or even trans issue. You can try removing the half shaft spacers to at least get that out of the way as process of elimination. Hopefully the guy who owned the car before you had enough sense to buy the two piece kind so you don't have to go pulling your shaft again. I have a feeling i just threw some time and money out the window. There's nothing quite as expensive as a cheap replacment.... My diff was making chatter sounds and i added some friction modifier to the diff and it quieted down in the tight turns, it was running smooth but now that's back too... The vibration is back and the chatter from the diff. The spacers are 2 piece so i can try taking those off in a couple days and then see if it makes a difference. I wonder if the bolts attaching the half shafts have gone bad maybe? I noticed when my friend and i were installing the axle, that the driver side pillow ball bushing looked ripped. We have access to my buddys shop and lift every other sunday. I also heard about differential mounts possibly being a factor |
Originally Posted by Nightshade1
(Post 24425830)
No the half shafts are NOT OEM they are DSS made in china.
(Post 24425838)
Sounds like you may have a couple different issues effecting vibration. Do you still have your old oem shafts? If so swap the cups right to left an reinstall them, then return the new ones.
this is all a big bummer throwing money at a phantom. I apreciate your help |
(Post 24425841)
No the axles were aftermarket before this change. I'm going to try taking off the spacers first and install a new pillow mount.
I had a similar issue but it was not restricted to speed. The car shuddered under any very hard acceleration. That turned out to be a bad rear joint (at the rear assembly) on my propeller shaft. A lightly used propeller shaft cured the problem.
Originally Posted by hecash
(Post 24425922)
I'm kind of leaning towards something in the propeller shaft because of the characteristics of the vibration. The vibrational feedback feels close to the gear shifter inside the car. Like you said it has nothing to really do with speed it's more hard acceleration, and mainly climbing from lower rpm in tall gears 4th through 6th do you feel it most pronounced. Plus nothing changed when i changed both axles; In fact the vibration lending itself to being more noticable more than likely due to the cheap design of the solid steel DSS axle half shafts. My AP1 is nothing crazy it probably pushes 260 hp at the wheel. It has a LSD with 4.44 gears. How susceptible are prop shafts to getting damaged in our cars? This is something i have not found. |
(Post 24425933)
Thanks for your input hecash.
How susceptible are prop shafts to getting damaged in our cars? This is something i have not found. And hey stay away from those cheap aftermarket axle/shaft options... :p |
Get some used axles, they will be better than the new parts store axles you have. Once those used oem axles wear out, have them rebuilt with new cv joints. Don't buy aftermarket axles.
