S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Under The Hood (https://www.s2ki.com/forums/s2000-under-hood-22/)
-   -   vtec sputtering, HELP! (https://www.s2ki.com/forums/s2000-under-hood-22/vtec-sputtering-help-235433/)
t00kosher Sep 15, 2004 04:21 AM
Lately, my 00 s2k has been sputtering in vtec and I cannot figure it out. I know that vtec is regulated by oil pressure, so i went ahead and changed the oil to see if would fix the problem but that seemed to not work. Does anyone have any advice or suggestions for me. I can't stand driving my car without going into vtec. The sound just sooths my soul
Hyper-X Sep 15, 2004 04:30 AM
First of all, are you trying to VTEC with less than 3 bars on the temp gauge? If so, that's normal.
Otherwise, do a search on MAP SENSOR WHACK and give that a try.
PedalFaster Sep 15, 2004 05:10 AM
shaggy and I had that problem in the car that we autocross -- the car would drive fine below the VTEC transition, but would cough and sputter above it. We eventually figured out that the problem was a loose spark plug wire which was vibrating out of contact, but only while in VTEC.
Good luck...
Steve
asopgem Sep 15, 2004 05:42 AM
what octane gas are you using?
Squeezer Sep 15, 2004 06:19 AM
I don't believe honda vtec is engaged by oil pressure. I believe when the ECU sees a certain RPM it enguages VTEC via the vtec selenoid. toyota's vvti-l system is based on oil pressure.
t00kosher Sep 15, 2004 07:21 AM
i use 92 octane always. i was thinking that it might be something with the coils or spark plugs. also what is a "map sensor whack"...I never go into vtec until the motor is fully warmed up. thanks for the input guys
RT Sep 15, 2004 07:30 AM
hit the map sensor w/ the handle of a screw driver
shingles Sep 15, 2004 08:30 AM
Not directly, but it makes sure that the oil pressure is above a certain level before engaging VTEC.
yogi Sep 15, 2004 11:52 AM
It doesn't use oil pressure to allow VTEC, the ECU does that. However, once engaged, it's oil pressure that actually pushes the pins in the rockers to engage VTEC.
t00kosher Sep 16, 2004 04:57 AM
thanks for all the help guys
© 2026 MH Sub I, LLC dba Internet Brands
