weird sanding-like noise
There is this faint noise I hear coming from the engine bay (more noticeable in neutral, 1st and 2nd and very low rpms ~ 2000-3000rpm)... it sounds like the sound very fine sandpaper makes when sanding... (could it be a misaligned belt)?
My car is fully warmed (three bars)... I noticed the sound today... only happens with the clutch released and gas slightly depressed...
Only mod I have is AEM CAI (which hums high-pitch as expected and doesn't sound related to this 'belt' noise )...
TIA
TIA
Originally Posted by Liemoanh,Mar 26 2005, 07:09 AM
If your driving while hearing this, you might be hearing your clutch engaging. I seem to hear this aswell.
i also hear it while in neutral... i hear the sound sometimes without the gas pressed, but all the time when the gas is pressed...
any way to get rid of it?
thanks guys... I did a search and found out it isn't covered by warranty by the previous posts... if it is the TO bearing.. any re-precussions (next to the sound) to not replacing it?
All s2k's have a very faint noise that can be heard from the TO bearing. My car has done it since day 1, and still does after a brand new TO bearing was installed with a ACT clutch. Every 00-04 I've been in has the same noise.
