what does it mean
Sometimes when I start the car, the dome lights and dashboard flickers. Is this normal? Sometimes it doesn't and sometimes it gets to the point where I think for a second it won't start. I reccently replaced the battery with oem, I had a yellow top duralast prior.
jk.
Mine does it too, I'll try to get a video of it in an hour or so to see we can compare.
I don't think it would be the alternator because it's on startup. If the dash and dome lights started getting dim when the car is turned ON then yes I would suspect the alternator. The only thing I could think of is the starter draws quite a lot of power on startup and if the battery can't supply the juice it'll dim/flicker the lights.
This is what mine does, I suspect I need a new battery.
http://www.youtube.com/watch?v=0_CeFQw3aeg
Does yours do a similar thing?
