S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Under The Hood (https://www.s2ki.com/forums/s2000-under-hood-22/)
-   -   White Smoke help (https://www.s2ki.com/forums/s2000-under-hood-22/white-smoke-help-1088008/)
Topplayer Jun 10, 2014 03:50 AM
White Smoke help
Hey guys, so my car is puffing white smoke and I am trying to solve it before my next event. Last night I did a compression test and leak down on a warm motor. The car has about 45k miles has a sos super charger pushing 410 and over the past 2 years has been tracked and auto x alot. Trying to figure out the next step I should take in trying to solve this. It is burning oil I am not sure how much since I never logged it. cylinder 3 looks alittle weaker than the others. Cylinder 4 had a darker spark plug. I plan to inspect the retainers tonight. any other things I should be doing next? I am researching now how to inspect retainers and valves since I have not experience with it yet.
compression test
230
238
225
226
leakdown
cylinder 1
4%
cylinder2
4%
cylinder 3
5%-6%
cylinder 4
4%
picture of the spark plugs: Order goes 4-3-2-1 number 4 looks a bit darker maybe 1000 miles on the plugs
https://i60.tinypic.com/33n8cxj.jpg
https://i58.tinypic.com/24plb20.jpg
https://i60.tinypic.com/nywlxw.jpg
Slowcrash_101 Jun 10, 2014 08:39 AM
It could be there was water in the last tank of gas you poured in your car. Happened to me once, car was blowing out white smoke, after my next fill up she stopped.
vtec9 Jun 10, 2014 08:49 AM
check coolant level. possibly get an oil analysis done and check for coolant. leakdown wouldn't point to bad head gasket, but you may be leaking and burning coolant somewhere.
dailyS2Kaddict Jun 10, 2014 04:53 PM
#1 most likely... but easily detected and by the looks of it your #2 and #3 plugs have been cleaned by something... Coolant?
#2 My opinion your chains stretched, timing is off and late ignition and burning oil but... that leaves a question why #2 and #3 plugs look cleaner
jWESTFOO Jun 11, 2014 09:46 AM
What would cause a chain to stretch other than regular use over time?
Topplayer Jul 18, 2014 11:36 AM
just for other peoples reference. I pulled the head swapped the head gasket, re did the valve guides and valve seals. car is perfect just got back from the track, strong as could be
bgoetz Jul 18, 2014 06:35 PM
IDK if that tells anyone much of anything. Based on the compression, leak down, and plugs I would have said your car was fine. Now white smoke, that is a different story. Did you figure out what exactly was causing the issue?
Slowcrash_101 Jul 20, 2014 06:43 AM
Head gasket.
jkelley Jul 23, 2014 07:48 AM
Wouldn't head gasket result in low compression and and air leak sound in dip tube or bubbling in coolant tank?
© 2026 MH Sub I, LLC dba Internet Brands
