Why no oil pressure gauge?
I know this has probably been hashed out here a 1000 times.....But why would Honda make an engine with a small displacement with that much power and no oil pressure gauge. I have read several post about making sure that the oil level is checked regularly. Im asking this question because (1) mabey there is something else that im missing and the car has fail safe system or just an idiot light or (2) You have to buy an aftermarket gauge....this would seem rather tacky to me. Reguardless of the situation im going to be an owner soon and would like some input on this.
Thanks Bill
Thanks Bill
Bill..........I just purchased my spa yellow last month and that was the first thing I noticed too. The only solution I could think of was a pillar mounted (2) gauge mount with oil pressure and water temp...................what do you think?............................................ .....................Bob
The car does come with an oil pressure (low) idiot light in the intrument cluster. Although you need to keep checking the oil "level", oil "pressure" will not help you to do this. You will still show good oil pressure even if you are down 2-3 quarts. Frightening, isn't it?
As already said, I'm one of those who like to know what it is anyway and I got one of those pillar pod mounts with oil pressure and water temp. I like to see my water temp in numbers, not just "bars".
Guys excellent idea......Viper nicely done.......i wonder if instead of a pillar mount they could be fitted in the dash.
Not necessarily on the gauge cluster but over to the right might be a cleaner install......just my opinion
Bill
Bill
Bill
Bill
Well, it was a little more involved than just drilling holes. I recall he made some sort of molded housing.
Originally posted by Road Rage
Xviper - does your pod water temp gauge creep up linearly as the car sits at idle? I ask because nearly all cars today, and all Hondas I have ever seen, do not have linearly calibrated gauges/indicators. Even though the thermistor in the sendor is constantly lowering the ohmic values it is sending to the gaue or instrument cluster driver module, the gauge sits at one spot. This is done so the gauge does not move up and down and worry idiots. In fact, I have actually removed the sensor and driven the gauge with a variable resistor lashup I use for testing electronics, and the resistance needed for the gauge to move puts in well into the range I consider "hot". Plus, without a gauge that truly reads linearly, one cannot see things like water pump degradation, plugged passages, etc. until it is too late.
Viper where did you find the gauges ??
https://www.s2ki.com/forums/showthread.php?...9038#post999038
