Will I be ok with Duralast parts?
#21
- Duralast not the same quality as OEM as i explained why above, from first hand experience
- OEM good quality, but bound to fail
- OEM can sand blast the worm and internal piston yourself as preventative
- Billman, OEM part, with updates like oiling and milling the mating surface to make OEM part better and less failure prone
- Ballade, a custom tct, that you MUST set preload for. If you **** up the preload, you can break your chain or worse.
all of the options above except ballade, have their preload already setup.
#22
I just explicitly wrote it, because I did the same shit during the interim of sandblasting my OEM.
I'd take pictures, but its in the trash.
- O-Ring grooves are different
- the bore is not the same so it leaks
- the worm gear is not internally threaded like OEM, so you need a vice/press/clamp to compress the piston to reinsert the grenade pin. OEM you remove the service plate, press the piston back and thread the service screw into the worm gear.
- The rounded end of the internal pin that supports the spring is smaller, the surface area at point of pressure at the piston is smaller. This end will wear fast and chatter, it also barely has a seat for the internal spring
- the internal spring is not as strong as oem and is shorter by a few mm
- the oil jet hole, has a smaller bore then OEM, it is also flush milled, where OEM is countersunk with a bevel.
To the OP. I've been around here for 3+ years at this point and have very few posts. This board is old and inactive at this point. Most questions that you could ask, especially at a surface level, have already been asked 10 different ways. Read more and you will find info. Billman is the resident s2k mechanic on this board and has a whole post about his TCT, why he does what he does, and he has revised it multiple times to improve it. Point is, read the boards. There is a wealth of knowledge and experience about this platform out there.
#23
btw I hope I didn't offend. Was just trying to be honest to the OP, about my experience with it.. and everyone here
#24
I dont think anyone in this thread said Billmans' sucks. I'm pretty sure everyone is under the consensus that Billman is the best. I personally was asking about the Ballade sports TCT as that was recommended to me by my mechanic (not over the billman one, just recommended in general) and so i was curious on why some people said it wasnt good. The preload seems like a good reason why though tbh.
Also i think a lot of people in this thread know the importance of a TCT. So even if you dont drive the car often, the fact that the part could fail prematurely is a HUGE concern. Remember your current TCT hasnt failed yet, its just on its way out and currently isnt causing any issues. What people dont want to see is in a year, you are coming back on this forum saying that your Duralast TCT failed completely without warning and now your engine is ruined. Do you really want to risk a whole engine vs just paying an extra 200$? Personally that wouldnt be worth it to me. I made that mistake in modding my old car and ended up spending a lot more money on quality mods than i needed to because i tried to be cheap and bought replica parts because they were cheap. For something as important as the TCT, do it right the first time and you wont risk catastrophic engine failure.
#25
I mean if you could provide me proof that duralast TCT's are shit and break after driving 1 mile and not just rely on "the most expensive part is the best" mentality that would be great.
Even if this is just OEM quality and only last 20k miles that is probably 2yrs of driving for me to get to that 20k additional miles.
I drove my civic hard. Drove it across country once and every day for work for over 2yrs and I only put 35k miles on it, the S2000 will only be used maybe once on the weekends to cruise around town.
There is no chance that any duralast part is in any way as good or better than OEM Honda. If it were as good/better, it would cost a HUGE amount more than the factory part. In every single case.
The OEM TCT can go quite a while before loosening up.
If this duralast part fails in a way that it destroys the rest of the engine, you'll probably be the first to know.
There's plenty of people who find out how "good" an aftermarket part is, first hand. And they never follow up their story with, "but I did save $(xx) when I bought it".
It's all junk, bruv.
#26
I understand your point but the exact same could be said for ANY part. My OEM one could fail without warning, the billman could fail without warning we could get hit by a bus without warning.
My thinking is a newer part is better than a failing older part, right?
#27
Look, I get it. I use Duralast parts all the time. Not on my S, but on my other cars. If I were in a bind, just to get the car on the road, I wouldn't hesitate to put Duralast parts on the S like pads, rotors, starter, alternator.
But I wouldn't trust such a critical part, that is very S specific like a tct, to Duralast.
Virtually everyone in this thread is giving the same advice. And its not just what people 'feel' is better. There is a tremendous amount of real world knowledge base on this topic.
Not all advice is good advice. Not all forum consensus is based on real facts. But this is one area where you can be sure the consensus is valid. tct is a mission critical component. The factory tct design has a flaw. Other tct designs are worse than factory. The billman tct is superior to all others.
#28
Option 3 is waiting to buy a part that you don't need to worry about
The OEM one in your car failed slowly with signs of failure after 160K miles.
Sure, the OEM one *could* fail without warning. But I can't recall 1 instance of this after the sale of 60somethingK S2000's in the US.
The duralast part could last 500K miles. But its KNOWN to be junk. Meaning the likelihood of failure is way higher. And its not the type of part you want failing.
You are more likely to get hit by that bus if you're running back and forth across a busy bus terminal at night wearing all black than you are crossing the street at a crosswalk.
Plus...why did you ask this question if you didn't have the same doubts? lol
Now you're like a Duralast spokesperson or something...
#29
Also, the Billman one has no failure account that I'm aware of....AND its mostly bought by people who note and scrutinize every single abnormal noise.
Mine's been great...but its only been on for a few K miles thus far.
Its $250, bruv. Not $2500
