Year 2000 Chirping sound from Trans Help
Old 03-15-2018, 02:17 PM
S2kDiva's Avatar
Unhappy Year 2000 Chirping sound from Trans Help
Hi,
This is my first post on this forum, please let me know if I have posted in the wrong area or need to change anything..
I have already replaced my clutch, Full OEM + ACT Pressure plate/Flywheel. I've also replaced my belt tensioner, and none of that had resolved the sound.
This video is not mine, however it does reciprocate the sound on my car fairly well. I have also had a shop confirm that the sound is coming from my transmission.
I haven't been able to find any solution or reason as to why my car is making this sound. I am not having any difficulties shifting or anything. If I had to complain about a problem that was coincidently getting worse when the sound had appeared, it would be getting into first gear or reverse from a complete stop.
Mainly reverse, I would constantly need to shift through all my gears in hopes that I could get into the reverse gear.
I'm just curious if anyone else had this problem and what it might be.
Old 09-29-2018, 08:20 AM
S2kDiva's Avatar
Bump
Old 09-29-2018, 11:30 AM
Billman250's Avatar
Received 1,244 Likes on 759 Posts
Is the sound present running in neutral, clutch not depressed?
Old 09-29-2018, 12:26 PM
S2kDiva's Avatar
Yeah, present in neutral and when clutch is pushed in and gear engaged.
Also checked all the pulleys, replaced belts. Next I was going to check my AC belt..
Old 09-29-2018, 05:02 PM
Billman250's Avatar
Is pilot bearing new?
Old 09-29-2018, 05:40 PM
S2kDiva's Avatar
Yup, the entire clutch assembly is brand new, pilot bearing is also oem.
I also replaced the master cylinder too
Old 08-26-2020, 05:14 AM
NateDaBear's Avatar
Default Same problem here
Did you ever find a solution? I just did a full flywheel/clutch/pressure plate replacement and I still have the chirping noise
Old 08-28-2020, 06:36 AM
Noahw's Avatar
Did you pack the inner ring of the Throw Out Bearing with grease and coat the input shaft & Threads with the special grease that comes with the clutch kits usually or at least just regular grease ?
Sounds like the Throw Out Bearing is dry to me just listening to the video.
windhund116 (08-28-2020)
Old 08-28-2020, 11:45 AM
windhund116's Avatar
Received 1,424 Likes on 954 Posts
Think the pilot bearing is a sealed unit. But, it does sound like dry or damaged bearing. A drag, since transmission would need to come out... again.
S2000 OEM pilot bearing. S2000 OEM pilot bearing.
Old 07-05-2021, 01:54 PM
S2kDiva's Avatar
Ive never found the problem, nor has anyone else I’ve taken it to. Ive just started to ignore it since it’s been almost 3 years now and it drives fine? Lol
Quick Reply: Year 2000 Chirping sound from Trans Help
