Yellow Box Settings?
Since there is not a single thread with yellow box settings, I thought we should have one.
If you don't know what a Yellow Box is, then you don't have one. But if you have changed your gears, or have change the size of your tires, you should have one. If you have questions about the Yellow box, you can search for the numerus thread on the topic, but this thread is just for settings. http://www.blackrobotics.com/switch.gif For Example here is mine. Model Year:2002 Trans MY:2004 Rear Gears:4.57 Rear Tire Size:285/30/18 Rear Rim Size:18x10 Switch Settings:01000001 Switch Setting %:16.25 How you calibrated:GPS Please copy this code, and enter your settings after the "/b]" Code:
Model Year: |
Model Year: 2000
Trans MY: 2000 Rear Gears: 4.44 Rear Tire Size: 255/40/17 Rear Rim Size: 17X9 Switch Settings: 00101000 Switch Setting %: +10 How you calibrated: traffic radar ps. Linking this to the FAQ's in Technical |
Model Year: 2000
Trans MY: 2000 Rear Gears: 4.44 Rear Tire Size: 255/35-18 Rear Rim Size: 18x8.5 Switch Settings: 00101010 Switch Setting %: 10.5 How you calibrated: GPS |
Model Year:2002
Trans MY:2002 Rear Gears:4.57 Rear Tire Size:245/40/17 Rear Rim Size:17 Switch Settings:0010 1000 Switch Setting %:10.00% How you calibrated:3 different cars matching my speed. NOTE: I left my speedo reading SLIGHTLY faster than I'm actually going. my factory speedo always seemed to be a bit quick by 2-3mph at freeway speeds (radar verified), so I decided to leave it as such. Otherwise I'd probably be about 10.5% or 11% |
Model Year:2002
Trans MY:2002 Rear Gears:4.57 Rear Tire Size:255/45/17 Rear Rim Size:17x9 Switch Settings:00100000 Switch Setting %:8% How you calibrated:Mile markers |
Can someone plz post the correct switch settings and % for the following:
Model Year: 2000 Trans MY: 2000 Rear Gears: 4.57 Rear Tire Size: 255/35/18 Rear Rim Size: 18x9 Switch Settings: ? Switch Setting %: ? TIA :hello: |
Model Year: 2002
Trans MY: 2002 Rear Gears: 4.57 Rear Tire Size: stock, worn s02's Rear Rim Size: stock Switch Settings: 00111000 Switch Setting %: 14% How you calibrated: mile markers (verified within 100 feet over 60 miles) |
Model Year: 2001
Trans MY: 2004 Rear Gears: 4.77 Rear Tire Size: stock '01 Rear Rim Size: stock '01 Switch Settings: 01100100 Switch Setting %: 25% How you calibrated: GPS |
Model Year:2000
Trans MY:2000 Rear Gears:4.57 Rear Tire Size:Stock Rear Rim Size:Stock Switch Settings:00111001 Switch Setting %:14.25 How you calibrated:Mile Markers on Highway with almost new tires. 14.50% was a bit much, and i THINK that 14.25% was a little under, but BARELY. This was done with 10 mile runs. |
Model Year: 2002
Trans MY: 2002 Rear Gears: 4.57 Rear Tire Size: 245/45/16 Rear Rim Size: 16 Switch Settings: 0010 0111 Switch Setting %: 9.75% How you calibrated: traffic speed radar |
