Brake Fluid
Received 1,562 Likes
This
The SL6 is a low viscosity fluid designed especially for cars with electronic brake systems whereas the Type 200 is a high performance fluid that replaces regular DOT 4 applications.
SL6 Specs are as follows:
Dry Boiling Point: 265 deg. C (509 deg. F). Wet Boiling Point: 170 deg. C (338 deg. F).
DOT 4 Type 200 specs are as follows:
Dry Boiling Point: 280 deg. C (536 deg. F). Wet Boiling Point: 198 deg. C (388 deg. F).
ATE 706402 Original SL.6 DOT 4 Brake Fluid
is designed to work faster in ABS. I do not track my 2009.The SL6 is a low viscosity fluid designed especially for cars with electronic brake systems whereas the Type 200 is a high performance fluid that replaces regular DOT 4 applications.
ThisATE 706402 Original SL.6 DOT 4 Brake Fluid
After seeing your first post I found those specs and will probably order the SL.6. The temperature ratings are close to the Typ 200 and it is designed for use with ABS.
I will not be able to put it to the test until next year when I hope to be back to the Dragon and possibly a couple track days.
energetic
Λιπαντικά - Καύσιμα - Χημικά Πρόσθετα
12-15-2010 01:02 AM
