Cordless Impact Wrench
Hi everyone. If you own a 1/2 drive cordless impact wrench, please tell us if you like it and what brand and model you purchased. The old Harbor Freight all plastic version I bought back in 2003 for changing tires at the autocross seems to be junk now. I didn't use it that much, but then again, I didn't pay that much for it either. The new HF models seem to have metal or partial metal bodies. I also see they offer a higher end model for $250. I'm not sure that it is worth the price and if I'm going to spend that much shouldn't I buy a better brand name like Milwaukee? I may buy another HF, but I thought I'd see what others are using.
AVE (youtube channel) did a teardown of a new Earthquake XT from HF just the other day. Surprisingly well built inside .. very surprisingly well built. He had already tested the air version of it and was only mildly impressed and the Hercules they sell was built like a toy inside. But the XT cordless was impressive.
He then tested it by torquing a bolt as high as that bolt would withstand (about 500 ft lbs) with a test setup and then tried breaking it loose with the XT. It didnt even flinch, so it at least took a bolt off with that much tq holding it together. I was surprised as well. I have a Rigid that does fine unless it is a very tight bolt. Good for regular stuff and wheels. I bought it because I already had the charger and two other tools. But I would not hesitate trying out the Earthquake based upon recent results. |
I got this one for speeding up tire swaps at events. Three settings, illuminated, and is pretty light weight. The battery holds a charge for a very long time; I haven't charged it in months and the battery is only down one bar (battery has a charge indicator). When my tires were mounted not too long ago, the shop used a pneumatic impact to put the wheels on. Needless to say, the lug nuts were on there tight and this tool popped them off instantly.
Ryobi 18-Volt ONE+ 3-Speed Lithium-Ion 1/2 in. Cordless Impact Wrench Kit-P1830 - The Home Depot |
Originally Posted by engifineer
(Post 24362796)
Originally Posted by Fokker
(Post 24362805)
Originally Posted by Legal Bill
(Post 24362824)
Good price point. Interesting that it is not sold in the stores.
Thanks for that information.
Definitely thanks! I have the less powerful model, along with the wrench. But I also have 2 of the 4ah batteries and charger. I was able to track down this link if you only need the tool:
Ryobi 18-Volt ONE+ 1/2 in. Cordless 3-Speed Impact Wrench (Tool-Only)-P261 - The Home Depot |
I have an old 18volt Milwaukee. It is 15 years old. One of the four batteries that I now have is an original. It has more than sufficient power to lift my car using the OEM scissor jack (I had a ½" drive socket welded onto the drive end.). I've used it hundreds of times to pull wheels for brake pad change and to lift the car at the race track. It is an ANIMAL!
