How To: Restore Headlights in ONE Step
Old Oct 21, 2013 | 11:42 AM
Autogeek.net's Avatar
Former Sponsor
Default How To: Restore Headlights in ONE Step
Headlight restoration has always been a guilty pleasure of mine. The before and after difference is always dramatic, and the look on the customer's face (or lucky co-worker) is most always worth the hard work. The keyword is most, because headlight restoration can be tedious and it often turns out to be a laborious task. Detailer's Pro Series is about to change that with the introduction of two all new headlight care products.
Detailer's Pro Series recently introduced a host of new headlight products, including a couple nifty kits that take the guesswork out of headlight restoration. As any loyal employee would do, I went searching in the parking lot for nasty, oxidized, sun-faded headlights. Since we're located in South Florida, that wasn't difficult to find.
Clear Headlights = Clear View Of the Road
Headlights are supposed to shine bright so you have a clear view of the road at night. If you drive a vehicle that was manufactured in the last 30 years, it most likely has headlight lenses that are constructed out of polycarbonate plastic. Polycarbonate plastic, while extremely durable and resilient against abrasion and impact, has poor resistance to UV rays, causing it to yellow and fade overtime, reducing visibility at night. Detailer’s All In One Headlight Restoring Polish gently polishes away the dull, faded layer of plastic to restore optical clarity so you can see clearly!
Detailer’s All In One Headlight Restoring Polish is the only product you need to restore the headlight lenses on your vehicle. In one simple step it:
  • Cleans by removing the embedded dirt and grime that washing doesn’t.
  • Compounds using micro and diminishing abrasives that quickly and effortlessly remove years of discoloration and yellowing, revealing a clear lens.
  • Polishes with the help of ultra-fine abrasives that further refine the surface, optimizing clarity while increasing vehicle safety.
Headlight Restoration - DP Style
Walk out to any random parking lot and you'll likely see this:
Oxidation, yellowing, and a cloudy haze on the surface of what's supposed to aid in vehicle safety - headlights. Driving around with oxidized headlights is like driving blind folded.
Do you think the headlights on this Toyota Avalon could possibly emit enough light for safe night time driving?
How To: Restore Headlights in ONE step, with ONE product
Remember when I said that headlight restoration is often a tedious and laborious task? Not any longer, thanks to the introduction to Detailer's All In One Headlight Restoring Polish.
Before polishing the headlight lenses, you need to make sure they're clean first. Since I had no interest in washing a beat up old Toyota Avalon, I gave the headlight lenses a quick down with Detailer's Waterless Auto Wash.
Next, I taped off any surrounding trim (this step is optional, but it's well worth the extra time). 3M masking tape worked beautifully.
Detailer's All In One Headlight Restoring Polish works best with a Lake Country THIN Foamed Wool Pad. One of these is included if you purchase the kit.
Note: I'm using a Makita 18 volt cordless drill equipped with a Lake Country Drill Backing Plate, which is also included in the kit (or available separately).
Here you can see I taped off half the lens. This is to give a clear indication of how well Detailer's All In One Headlight Restoring Polish works.
I set the Makita drill to about 1200 RPM. You can also use a rotary or dual action polisher.
There's more involved in restoring optical clarity to a plastic lens than just removing the top layer of oxidation; Detailer's All In One Headlight Restoring Polish is packed pull of micro polishing agents that pull embedded dirt out of the pores of the lens, further increasing clarity. Check out how dirty the pad is after polishing just a small section of the lens:
50/50
Completely restored:
What's impressive about the performance of Detailer's All In One Headlight Restoring Polish is that it made the lens this clear after just one step with a wool pad.
Protecting the Headlight Lens
Headlights come equipped from the factory with a protective coating. As soon as you polish the lens to remove the oxidation, what remains of this coating is removed as well. If you don't apply some type of protection on the lens, it will oxidize and yellow again in no time.
Another headlight-specific product just introduced in the DP line is Headlight Protectant Spray. Detailer’s Headlight Protectant Spray is a polymer sealant that blankets your headlight lenses in a clear, durable film of protection. Advanced cross-linking polymers seal the pores of plastic headlight lenses to prevent degradation caused by UV rays, water, and environmental pollution. Use on clear plastic headlight lenses, vinyl windows, and motorcycle windscreens. Treated surfaces will resist yellowing, fading and discoloration. Application is as simple as spraying on and wiping off. Apply a coat every couple months for maximum protection.
In no time at all the headlights on this Toyota Avalon looked as good if not better than the day the car was new. By removing the oxidation and yellowing, nighttime visibility will increase dramatically as well as the overall appearance of the vehicle.
Detailer's All In One Headlight Restoring Polish makes multi-step headlight restoration systems a thing of the past.
On Autogeek.net
Detailer's Total Headlight Restoration Kit
Detailer's Headlight Protectant Spray
Makita 18V LXT Lithium-Ion Cordless 1/2 inch Driver Drill Kit
3M Automotive Performance Masking Tape
Old Nov 1, 2013 | 11:02 AM
J Schmidt's Avatar
Damn.
Are all headlights that easy?
Old Nov 9, 2013 | 10:26 AM
S2KRAY's Avatar
Active Streak: 30 Days
Top Answer: 1
How is this product different than Meguiar's. I did not have favorable results using Meguiar's.
Old Nov 10, 2013 | 08:52 AM
Carbon Blue's Avatar
while this seems like a great product for lightly/moderately damaged headlamps, id like to see a more abused headlamp where the damaged layer is much thicker and caked on. I dont think ive ever used any one step product that has achieved better results than a multiprocess wetsand/compound job.
Old Nov 18, 2013 | 01:27 PM
Former Sponsor
Originally Posted by J Schmidt
Damn.
With the right products and a little bit of knowledge, yes.
Which Meguiars product?
A compound is never going to be as abrasive as rubbing a piece of sand paper across the surface, so for some applications, sanding may still be required. For the other 99$ of hreadlights that need to be restored, Detailer's All In One Headlight Restoring Polish is all you need.
Old Jan 9, 2014 | 05:16 AM
J Schmidt's Avatar
I ordered one of these kits and tried it out on my 06 headlights which were a bit cloudy and wawlaw, it worked like the OP demonstrated. It did not remove all the tiny pits probably rock impacts. Is there a way to remove those? I figure you need a pretty aggressive sand. Did my 07 fit's at the same time which were terrible and it worked pretty good except I think I needed another purple pad as the original was pretty worn after 4 headlights. Where can I get purple pads?
kylemonster85
Dec 28, 2009 02:35 PM
redmen
Sep 24, 2009 05:00 AM
HandofBoB
Dec 1, 2006 09:58 AM
silverhand
Mar 2, 2003 08:10 PM
JohnA
Oct 25, 2000 07:34 AM
