S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Wash and Wax (https://www.s2ki.com/forums/s2000-wash-wax-15/)
-   -   Lexan window (https://www.s2ki.com/forums/s2000-wash-wax-15/lexan-window-1056514/)
Suzuka-13 Nov 1, 2013 11:00 PM
Lexan window
I have a question for the owners that have Lexan windows on their Mugen tops ? How do you dry them or clean them after a car wash ? I have heard they scratch very easily ,any tips would be great !
xoz Nov 2, 2013 12:47 AM
"Gently dry or go for a quick drive" product called plexus works well to protect, but it definitely scratches easily. No marker pens writing in it at all as will leave a ghost imprint.
zeroptzero Nov 2, 2013 05:14 PM
I bought my Mugen top used, I gave it an initial polish with Meguiars Plast-X which cleaned up light surface scratches nicely - interior and exterior.
The obvious first rule is that I never touch the window when it's dry.
After a wash I will just pat dry it, or wipe gently with a microfiber as long as the window is still wet. Then I proceed to protect it with a coat of Plexus, I use it on the interior as well as the exterior. You basically spray it on and wipe with a dry microfiber towel until it is clear and dry.
If the window is dry and dusty and I am not planning on washing the vehicle I will spritz the window with soapy water mix from a spray bottle (every detailer should have one or two), then wipe or pat dry as above. I finish with a coat of Plexus. Plexus leaves a protective wax finish, and will not attract dust, so the window stays clean longer.
I have given the window a coat of Autoglym wax in the past, but I don't do that too often, maybe once a year. Using Plexus is my favourite regular maintenance product for the lexan window, and can be used other plastic parts such as light fixtures etc.
importkid Nov 2, 2013 09:36 PM
http://i21.geccdn.net/site/images/n-...p/30541279.jpg
Suzuka-13 Nov 2, 2013 09:58 PM
Thanks for all the feed back guys !
Suzuka-13 Nov 2, 2013 10:07 PM
Originally Posted by importkid (Post 22859186)
LiL leaf blower?
importkid Nov 2, 2013 10:43 PM
Heated and filtered, but for the most part yes. It's an awesome little tool to have for sure.
redboost10 Nov 16, 2013 02:59 PM
I put a film on all my lexan windows. Never have to worry about them again.
© 2026 MH Sub I, LLC dba Internet Brands
